I got my Framework Laptop 13 (AMD Ryzen 7040Series) in the beginning of january and I’m loving it. I installed Fedora 39 and mostly all worked out of the box, super experience!
There are just some little things which annoy me and do not work as I wish too.
These issues are only in docked mode. As I used a Lenovo x1-carbon G9 before I’m using the ThinkPad Thunderbolt 3 Dock (40AN) for my Framework.
charging over usb-c
Sometimes when i plug-in the usb-c cable the Framework is not charging, I have to reboot, then it works.
Monitor not always wake up from sleep
Often when I return to my desk the Monitors do not wake up from sleep.
I have to disconnect the docking station, open the lid, log back in, put the dock back in.
Mostly the monitors work after that, sometimes I have to reboot.
shutdown does not work properly when docked
When i shutdown the Framework while docked, the system is hanging in fedora shutdown splash. I have to open the lid and hardly shutdown then. The splash is only visible on the framework monitor and not on the external.
How to debug this problems? If you need any info, please tell me.
Thanks in advance!
Unfortunately Framework doesn’t support or has fairly limited support with third party docking stations, might be best to stick with standard peripherals or anything that comes with framework laptop, like the framework usb-c charger.
The charging problem also occurs with framework usb-c charger.
I still have to reboot, to make it work. As I said If I you need any logs or can give me a hint where to search, I’ll try own my own to find the cause.
@marv recently, the shutdown bug has hit me as well. I’ve been on fedora 44 (kinoite version) for a while, before on fedora 43, no issues until recently. I’m using the Lenovo Thunderbolt 3 Essential Dock (40AV). Also the ryzen 7040 series.
