Framework 16 TB dock issues
Ubuntu 24.04
Which release version?
24.04.3
Which kernel are you using?
6.14.0-33-generic
3.07
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Im getting various issues with my WD19TB dock, depending on the port that it is plugged into the behavior changes.
i have tested it for port 1,2,4, and 5 using the same expansion card (different card makes no change). - Expansion Card Slot functionality on Framework Laptop 16 (AMD Ryzen™ 7040 Series)
PORT1:
[ 2354.859770] ucsi_acpi USBC000:00: unknown error 256
[ 2354.859792] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[ 2359.721208] usb usb7-port1: Cannot enable. Maybe the USB cable is bad?
[ 2360.609361] usb usb7-port1: Cannot enable. Maybe the USB cable is bad?
[ 2360.609533] usb usb7-port1: attempt power cycle
[ 2361.561255] usb usb7-port1: Cannot enable. Maybe the USB cable is bad?
[ 2362.449314] usb usb7-port1: Cannot enable. Maybe the USB cable is bad?
[ 2362.449463] usb usb7-port1: unable to enumerate USB device
boltctl:
○ Dell WD19TB Thunderbolt Dock #2
├─ type: peripheral
├─ name: WD19TB Thunderbolt Dock
├─ vendor: Dell
├─ uuid: b4030000-0072-740e-838c-3f3b1c22c000
├─ generation: Thunderbolt 3
├─ status: disconnected
├─ authorized: Tue 19 Nov 2024 05:17:30 PM UTC
├─ connected: Tue 19 Nov 2024 05:17:30 PM UTC
└─ stored: Tue 19 Nov 2024 05:17:30 PM UTC
├─ policy: iommu
└─ key: no
○ Dell Thunderbolt Dock
├─ type: peripheral
├─ name: Dell Thunderbolt Dock
├─ vendor: Dell
├─ uuid: d7030000-00b1-a708-220a-f3e5e604ba1c
├─ authorized: Fri 31 May 2024 10:21:27 PM UTC
├─ connected: Fri 31 May 2024 10:21:27 PM UTC
└─ stored: Fri 31 May 2024 08:03:13 PM UTC
├─ policy: iommu
└─ key: no
○ Dell Thunderbolt Cable
├─ type: peripheral
├─ name: Dell Thunderbolt Cable
├─ vendor: Dell
├─ uuid: d7030000-0082-7d08-22c4-b5d76e652019
├─ policy: iommu
└─ key: no
○ Dell WD22TB4 Thunderbolt Dock
├─ type: peripheral
├─ name: WD22TB4 Thunderbolt Dock
├─ vendor: Dell
├─ uuid: ae488780-0024-61e8-ffff-ffffffffffff
├─ generation: USB4
├─ authorized: Sat 02 Aug 2025 11:49:05 PM UTC
├─ connected: Sat 02 Aug 2025 11:49:05 PM UTC
└─ stored: Sat 08 Jun 2024 05:14:05 PM UTC
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ uuid: be030000-0072-741e-03c9-3883e0f09801
├─ authorized: Fri 03 Oct 2025 11:59:38 PM UTC
├─ connected: Fri 03 Oct 2025 11:59:37 PM UTC
└─ stored: Wed 18 Sep 2024 12:17:11 AM UTC
├─ policy: iommu
└─ key: no
PORT 2:
DMESG:
[ 2492.323852] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
[ 2492.863033] [drm] DM_MST: starting TM on aconnector: 0000000024113160 [id: 117]
[ 2492.868708] [drm] DM_MST: DP14, 2-lane link detected
[ 2493.278457] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2493.524679] [drm] Downstream port present 1, type 2
[ 2494.006718] amdgpu 0000:c1:00.0: amdgpu: MES failed to respond to msg=MISC (WAIT_REG_MEM)
[ 2494.006799] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] ERROR failed to reg_write_reg_wait
[ 2494.166467] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2494.166539] usb usb1-port1: attempt power cycle
[ 2494.278646] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 37 using xhci_hcd
[ 2494.292237] usb 2-1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.62
[ 2494.292254] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2494.292258] usb 2-1: Product: Dell dock
[ 2494.292262] usb 2-1: Manufacturer: Dell Inc.
[ 2494.319673] hub 2-1:1.0: USB hub found
[ 2494.319919] hub 2-1:1.0: 4 ports detected
[ 2494.842722] [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:e8cf:dfae:51af:fc9c DST=ff02:0000:0000:0000:0000:0000:0000:000c LEN=655 TC=0 HOPLIMIT=1 FLOWLBL=63164 PROTO=UDP SPT=36862 DPT=3702 LEN=615
[ 2494.921279] [UFW BLOCK] IN=wlp1s0 OUT= MAC=fc:b0:de:18:1e:3d:7c:a7:b0:6f:f6:a1:86:dd SRC=fe80:0000:0000:0000:7ea7:b0ff:fe6f:f6a1 DST=fe80:0000:0000:0000:e8cf:dfae:51af:fc9c LEN=1250 TC=0 HOPLIMIT=64 FLOWLBL=591346 PROTO=UDP SPT=3702 DPT=36862 LEN=1210
[ 2495.183514] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2496.070566] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2496.070707] usb usb1-port1: unable to enumerate USB device
[ 2496.133307] usb 2-1.3: new SuperSpeed USB device number 38 using xhci_hcd
[ 2496.160812] usb 2-1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.23
[ 2496.160827] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2496.160832] usb 2-1.3: Product: Dell dock
[ 2496.160837] usb 2-1.3: Manufacturer: Dell Inc.
[ 2496.194448] hub 2-1.3:1.0: USB hub found
[ 2496.195883] hub 2-1.3:1.0: 4 ports detected
[ 2496.266622] usb 2-1.4: new SuperSpeed USB device number 39 using xhci_hcd
[ 2496.278980] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.11
[ 2496.278987] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 2496.278991] usb 2-1.4: Product: USB 10/100/1000 LAN
[ 2496.278994] usb 2-1.4: Manufacturer: Realtek
[ 2496.278997] usb 2-1.4: SerialNumber: 111000001
[ 2496.366156] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 39 using xhci_hcd
[ 2496.442391] r8152 2-1.4:1.0 eth0: v1.12.13
[ 2496.504436] r8152 2-1.4:1.0 enx70b5e81c1023: renamed from eth0
BOLTCTL:
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ generation: USB4
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
PORT 4:
DMESG:
[ 2582.450431] usb 5-1: new high-speed USB device number 30 using xhci_hcd
[ 2582.520347] ucsi_acpi USBC000:00: unknown error 0
[ 2582.520368] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[ 2582.582267] usb 5-1: New USB device found, idVendor=0bda, idProduct=5487, bcdDevice= 1.62
[ 2582.582284] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2582.582291] usb 5-1: Product: Dell dock
[ 2582.582296] usb 5-1: Manufacturer: Dell Inc.
[ 2582.620691] hub 5-1:1.0: USB hub found
[ 2582.621287] hub 5-1:1.0: 5 ports detected
[ 2582.971431] usb 5-1.3: new high-speed USB device number 31 using xhci_hcd
[ 2583.075701] usb 5-1.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.23
[ 2583.075711] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2583.075715] usb 5-1.3: Product: Dell dock
[ 2583.075719] usb 5-1.3: Manufacturer: Dell Inc.
[ 2583.131398] hub 5-1.3:1.0: USB hub found
[ 2583.133814] hub 5-1.3:1.0: 6 ports detected
[ 2583.272436] usb 5-1.5: new high-speed USB device number 32 using xhci_hcd
[ 2583.360432] usb 5-1.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 2.01
[ 2583.360441] usb 5-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 2583.360446] usb 5-1.5: Product: Dell Thunderbolt Dock WD19TB
[ 2583.360450] usb 5-1.5: SerialNumber: 2100
[ 2583.421295] hid-generic 0003:413C:B06E.0038: hiddev5,hidraw14: USB HID v1.11 Device [Dell Thunderbolt Dock WD19TB] on usb-0000:c3:00.3-1.5/input0
[ 2583.494409] usb 5-1.3.2: new low-speed USB device number 33 using xhci_hcd
[ 2583.560790] hid-generic 0003:413C:B06E.0039: hiddev5,hidraw14: USB HID v1.11 Device [Dell Thunderbolt Dock WD19TB] on usb-0000:c3:00.3-1.5/input0
[ 2583.603713] usb 5-1.3.2: New USB device found, idVendor=05ac, idProduct=024f, bcdDevice= 1.11
[ 2583.603722] usb 5-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2583.603726] usb 5-1.3.2: Product: USB KEYBOARD
[ 2583.603729] usb 5-1.3.2: Manufacturer: HAILUCK CO.,LTD
[ 2583.667024] hid-generic 0003:413C:B06E.003A: hiddev5,hidraw14: USB HID v1.11 Device [Dell Thunderbolt Dock WD19TB] on usb-0000:c3:00.3-1.5/input0
[ 2583.683801] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.3/5-1.3.2/5-1.3.2:1.0/0003:05AC:024F.003B/input/input47
[ 2583.734644] apple 0003:05AC:024F.003B: input,hidraw15: USB HID v1.10 Keyboard [HAILUCK CO.,LTD USB KEYBOARD] on usb-0000:c3:00.3-1.3.2/input0
[ 2583.748721] apple 0003:05AC:024F.003C: Fn key not found (Apple Wireless Keyboard clone?), disabling Fn key handling
[ 2583.748804] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.3/5-1.3.2/5-1.3.2:1.1/0003:05AC:024F.003C/input/input48
[ 2583.749206] apple 0003:05AC:024F.003C: input,hiddev6,hidraw16: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-0000:c3:00.3-1.3.2/input1
[ 2583.826439] usb 5-1.3.4: new high-speed USB device number 34 using xhci_hcd
[ 2583.999712] usb 5-1.3.4: New USB device found, idVendor=0bda, idProduct=402e, bcdDevice= 0.01
[ 2583.999724] usb 5-1.3.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2583.999729] usb 5-1.3.4: Product: USB Audio
[ 2583.999733] usb 5-1.3.4: Manufacturer: Generic
[ 2583.999737] usb 5-1.3.4: SerialNumber: 200901010001
[ 2585.026430] usb 5-1.3.5: new high-speed USB device number 35 using xhci_hcd
[ 2585.126829] usb 5-1.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[ 2585.126842] usb 5-1.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2585.126847] usb 5-1.3.5: Product: Dell dock
[ 2585.367511] amdgpu 0000:c1:00.0: [drm] Alt mode has timed out after 214 ms
[ 2585.839760] hid-generic 0003:413C:B06F.003D: hiddev7,hidraw17: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.3-1.3.5/input0
[ 2585.951783] hid-generic 0003:413C:B06F.003E: hiddev7,hidraw17: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.3-1.3.5/input0
BOLTCTL:
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ generation: USB4
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
PORT 5:
DMESG:
[ 2682.697204] usb 2-2.1: new SuperSpeed Plus Gen 2x1 USB device number 43 using xhci_hcd
[ 2682.710615] usb 2-2.1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.62
[ 2682.710633] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2682.710640] usb 2-2.1: Product: Dell dock
[ 2682.710646] usb 2-2.1: Manufacturer: Dell Inc.
[ 2682.738042] hub 2-2.1:1.0: USB hub found
[ 2682.738754] hub 2-2.1:1.0: 4 ports detected
[ 2682.799444] usb 1-2.1: new high-speed USB device number 64 using xhci_hcd
[ 2682.909954] usb 1-2.1: New USB device found, idVendor=0bda, idProduct=5487, bcdDevice= 1.62
[ 2682.909963] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2682.909967] usb 1-2.1: Product: Dell dock
[ 2682.909970] usb 1-2.1: Manufacturer: Dell Inc.
[ 2682.958292] hub 1-2.1:1.0: USB hub found
[ 2682.958700] hub 1-2.1:1.0: 5 ports detected
[ 2683.022663] usb 2-2.1.3: new SuperSpeed USB device number 44 using xhci_hcd
[ 2683.051131] usb 2-2.1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.23
[ 2683.051137] usb 2-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2683.051139] usb 2-2.1.3: Product: Dell dock
[ 2683.051141] usb 2-2.1.3: Manufacturer: Dell Inc.
[ 2683.075924] hub 2-2.1.3:1.0: USB hub found
[ 2683.077494] hub 2-2.1.3:1.0: 4 ports detected
[ 2683.144454] usb 2-2.1.4: new SuperSpeed USB device number 45 using xhci_hcd
[ 2683.156124] usb 2-2.1.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.11
[ 2683.156134] usb 2-2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 2683.156138] usb 2-2.1.4: Product: USB 10/100/1000 LAN
[ 2683.156142] usb 2-2.1.4: Manufacturer: Realtek
[ 2683.156146] usb 2-2.1.4: SerialNumber: 111000001
[ 2683.246271] r8152-cfgselector 2-2.1.4: reset SuperSpeed USB device number 45 using xhci_hcd
[ 2683.320228] r8152 2-2.1.4:1.0 eth0: v1.12.13
[ 2683.336434] usb 1-2.1.3: new high-speed USB device number 65 using xhci_hcd
[ 2683.338950] [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:e8cf:dfae:51af:fc9c DST=ff02:0000:0000:0000:0000:0000:0000:000c LEN=655 TC=0 HOPLIMIT=1 FLOWLBL=24303 PROTO=UDP SPT=46429 DPT=3702 LEN=615
[ 2683.394656] r8152 2-2.1.4:1.0 enx70b5e81c1023: renamed from eth0
[ 2683.441216] usb 1-2.1.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.23
[ 2683.441225] usb 1-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2683.441229] usb 1-2.1.3: Product: Dell dock
[ 2683.441232] usb 1-2.1.3: Manufacturer: Dell Inc.
[ 2683.502744] hub 1-2.1.3:1.0: USB hub found
[ 2683.504104] hub 1-2.1.3:1.0: 6 ports detected
[ 2683.645441] usb 1-2.1.5: new high-speed USB device number 66 using xhci_hcd
[ 2683.734452] usb 1-2.1.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 2.01
[ 2683.734463] usb 1-2.1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 2683.734468] usb 1-2.1.5: Product: Dell Thunderbolt Dock WD19TB
[ 2683.734472] usb 1-2.1.5: SerialNumber: 2100
[ 2683.793147] hid-generic 0003:413C:B06E.0046: hiddev0,hidraw2: USB HID v1.11 Device [Dell Thunderbolt Dock WD19TB] on usb-0000:c1:00.3-2.1.5/input0
[ 2683.864417] usb 1-2.1.3.2: new low-speed USB device number 67 using xhci_hcd
[ 2683.927152] hid-generic 0003:413C:B06E.0047: hiddev0,hidraw2: USB HID v1.11 Device [Dell Thunderbolt Dock WD19TB] on usb-0000:c1:00.3-2.1.5/input0
[ 2683.970037] usb 1-2.1.3.2: New USB device found, idVendor=05ac, idProduct=024f, bcdDevice= 1.11
[ 2683.970046] usb 1-2.1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2683.970050] usb 1-2.1.3.2: Product: USB KEYBOARD
[ 2683.970053] usb 1-2.1.3.2: Manufacturer: HAILUCK CO.,LTD
[ 2684.036364] hid-generic 0003:413C:B06E.0048: hiddev0,hidraw2: USB HID v1.11 Device [Dell Thunderbolt Dock WD19TB] on usb-0000:c1:00.3-2.1.5/input0
[ 2684.054516] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3.2/1-2.1.3.2:1.0/0003:05AC:024F.0049/input/input51
[ 2684.114683] apple 0003:05AC:024F.0049: input,hidraw11: USB HID v1.10 Keyboard [HAILUCK CO.,LTD USB KEYBOARD] on usb-0000:c1:00.3-2.1.3.2/input0
[ 2684.127616] apple 0003:05AC:024F.004A: Fn key not found (Apple Wireless Keyboard clone?), disabling Fn key handling
[ 2684.127785] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3.2/1-2.1.3.2:1.1/0003:05AC:024F.004A/input/input52
[ 2684.128242] apple 0003:05AC:024F.004A: input,hiddev5,hidraw12: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-0000:c1:00.3-2.1.3.2/input1
[ 2684.203448] usb 1-2.1.3.4: new high-speed USB device number 68 using xhci_hcd
[ 2684.376770] usb 1-2.1.3.4: New USB device found, idVendor=0bda, idProduct=402e, bcdDevice= 0.01
[ 2684.376781] usb 1-2.1.3.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2684.376786] usb 1-2.1.3.4: Product: USB Audio
[ 2684.376790] usb 1-2.1.3.4: Manufacturer: Generic
[ 2684.376793] usb 1-2.1.3.4: SerialNumber: 200901010001
[ 2685.429419] usb 1-2.1.3.5: new high-speed USB device number 69 using xhci_hcd
[ 2685.529404] usb 1-2.1.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[ 2685.529428] usb 1-2.1.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2685.529433] usb 1-2.1.3.5: Product: Dell dock
[ 2686.243536] hid-generic 0003:413C:B06F.004B: hiddev6,hidraw13: USB HID v1.11 Device [Dell dock] on usb-0000:c1:00.3-2.1.3.5/input0
[ 2686.316914] hid-generic 0003:413C:B06F.004C: hiddev6,hidraw13: USB HID v1.11 Device [Dell dock] on usb-0000:c1:00.3-2.1.3.5/input0
BOLTCTL:
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ generation: USB4
├─ policy: iommu
└─ key: no
├─ type: peripheral
├─ vendor: Dell
├─ policy: iommu
└─ key: no
What plugging this dock, which i know works as it works on my work laptops, i also have another WD19TB that i have this same behavior on as well with only the framework.
PORT1 - Nothing
PORT2- Video only
PORT4- USB only
PORT5- USB only
Just last week this dock worked without issue on port1. Hopefully someone else has run into this before and knows what the fix may be.
I never got the WD19TB to run stable with my FW16 or my youngen’s FW13.
It was dependent on the kernel version. Sometimes it worked, sometimes it didn’t.
It all cam down to the ThunderBolt code in the kernel which changed from version to version and caused havoc. If it worked before, reboot into the old kernel.
In the end, I was fed-up and bought a cheap Mokin USB-C docking station, and I have no more problems. Just works.
For whatever it’s worth, I use a Jsaux 11-in-1 that I bought originally for my Steam Deck and haven’t had any issues. Sorry to hear you’re having issues. I can’t trust any ports except #1 and #4 with external SSD’s for whatever reason.
Must be Linux, on Windows, I had 2 WD19TB running on port 1 and 4.
Currently I have WD19TB and WD22TB connected.
This issue came about with a kernel update that Ubuntu did, it appears the latest versions of the kernel have a USB-C issue.
Updating to 6.17.0 allowed all the USB-C ports to work again.
