ECC Memory?
Hello, there is no mention if the memory is ECC. On the spec sheets of the AMD CPU it says that it support ECC. Would be nice if the information was clarify since it can be confusing for consumers.
Thank You!
With their APUs, AFAIK only the Pro chips have support for ECC, and on AMD’s website it says the AI Max+ 395 doesn’t have AMD PRO technologies.
ECC is not supported on Framework Desktop.
:frowning: It would have been awesome to deploy kubernetes nodes with the frame.work “desktop”
