Summary of Issue:
The PC fails to boot from a known-good bootable USB drive.
The GRUB bootloader (from Linux installers) successfully launches, indicating the BIOS is correctly identifying and starting from the USB drive.
The process fails immediately after GRUB attempts to load the operating system kernel.
Specific Error Messages Observed:
The system has displayed several critical, low-level errors, including:
KERNEL PANIC: No Media in HD0
VFS: Cannot open root device “hd0”
alloc magic is broken at 0x : 77779_
Aborted
Comprehensive Troubleshooting Steps Performed:
1. Verified Boot Media Integrity (Ruled out as the cause):
Multiple Operating Systems: Tested installers for Fedora (Netinstall and Full), Debian (Netinstall), and Ubuntu. All failed at the same point.
Fresh Downloads: Downloaded fresh ISO images for each OS and verified their checksums to ensure they were not corrupt.
Multiple Creation Tools: Used different reliable tools (e.g., Rufus, BalenaEtcher) to create the bootable drives.
Multiple Physical USB Drives: Tested with several different physical USB sticks to rule out a faulty drive.
2. Confirmed BIOS/UEFI Settings:
Boot Order: Confirmed the USB drive is set as the first boot priority.
Secure Boot: The issue persists with Secure Boot disabled.
I have a Framework 13 Ryzen AI 5 340
I tried to update the bios, without success using EFI on a usb stick.
