I got my framework assembled and plugged in my Linux boot drive and it can see the drive, but when I try to boot it I get nothing but a static cursor on the screen. I have tried many of the other mentioned ways in the community, bit none of they see to work.
Secure boot as been turned off, I can access all the bios menu and settings.
I am using Multisystem boot, I have been using it for years and the drives work when I test on my Lenovo X1. The grub on the usb allows for me to select the Linux ISO.
There is a EFI partition, and I have never seen this issue before this with Multiusystem USB drive. It’s been my go to for years as it allows one to put multiple ISO on the USB. But i erase my drive and used Balena Etcher to make the drive and it worked.
