Hi all,
I’m having a strange issue where the built-in Ethernet on my Framework Desktop almost always appears invisible to the OS when the machine is first powered on.
And I do mean “invisible”: in linux, for example, the output of ‘lspci’ is simply missing two devices until I reboot.
00:02.1 PCI Bridge: [….] Strix Halo GPP Bridge (rev 02) […]
bf:00.0 Ethernet controller: Realtek Semiconductor co., Ltd RTL8126 5Gbe […]
As soon as I restart the computer, they suddenly appear again and the OS acts like everything is fine. Doesn’t appear to matter how I restart it, as long as I don’t power it off.
Anyway, this is all very weird, and I’m just wondering if anyone else has a similar problem or any idea what might be going on.
I’m pretty confident it’s not an OS problem, since it happens regardless of OS, and of course I’ve tested the officially supported ones.
but to make things even stranger, the ethernet hardware itself also seems to be working ok before the OS tries is booted. The UEFI network stack seems fine - I can boot into a UEFI shell with it enabled and the hardware is visible and works perfectly.
Thanks in advance for any insight (or at least commiseration) any of you can provide.
