Hello,
for some reason, my 7700s is not detected anymore. It worked after i received it (Batch 17), the i swapped it for the normal Bay for some time and now i wanted to change it back to the GPU (also swapped memory as mine was not supported and now i got supported sticks)
In the Bios the point “Expansion Bay” says: “Not detected”, the module seems to be placed correct and setting the Bios to default did not help too.
Does anybody has an idea what the issue could be? ![]()
Did you remember to switch out the shell interposer for the graphics module interposer?
Graphics interposer: Framework
Shell interposer: Framework
Yes, the interposer is the one for the GPU
