(at the moment of writing the 2nd half is still being printed)
The first step was to gain a second display. A friend was upgrading to the 2.8k panel so I could get a second 2.2k panel for cheap. Having an external display with the exact same size and resolution seems like a good plan.
It has USB-C allowing it to get display and power over 1 cable. But it has 2 of them, allowing USB Power Delivery passtrough. And it also has micro-usb for separate power, and mini-hdmi, for whenever you need that I guess.
Then I needed a case for it. I found one on printables but I wanted to re-use my existing bezel at the front. So I designed my own. You can separate the two parts of the bezel to get a flatter bezel without the chin to make it fit on top of my design.
I used a bunch of 6x4x2 mm magnets that I somehow had sticking around from a previous project. And I used some leftover aluminium bits (I think it’s a flooring profile) for extra stiffness. I designed it in 2 parts to glue together since that’s the only way it’ll fit on a typical 3d printers build plate. I was in a playful mood so I added a wavy two-color effect.
4 port USB 2.0 hub. There are multiple unused but labeled downstream USB ports on the board. At least one is broken out on the daughterboard with the buttons, and at least another is on another FPC connector. The pinouts are actually silkscreened on the board <3
Oh, looks like you got a really nice and slim result! I love compact designs, which waste barely a millimeter. Takes more effort, usually though.
Which glue did you use?
That would really top it off. As this look just ideal to slip into a laptop bag along with your Framework, or other laptop for that matter.
Do you think there might be enough space in a couple spots to add some interlocking joints between the two halves? To take some dependence off of using a good strong glue.
I was procrastinating on that decision. I used cheap boring CA glue for the magnets and I was hoping to use that for the halves (mostly via the alu strips) but I guess my Plan B could be 2 component epoxy if the CA glue fails.
Yup. I specifically searched ebay for boards compatible with the BOE NE135FBM-N41. (Framework docs, panel specs).
I use a Bambu X1 carbon at my local hackerspace. But the looks are mostly dictated by the matte filament and the textured buildplate. I’m pretty sure I can get almost identical results on any FDM printer with a heated textured buildplate. I think I would choose a Prusa XL if I had access to one, since they would fit the entire design in one piece
please let me know if you release the stls personally my cad skills are shit but i’d love some files with a built in kickstand and slots to attach a cover
Hi so awesome design, I’m trying to make it aswell but I only can find the right part of the 3d model in the files you shared. am i right or am I not looking at the right place. Could you help me.
The openscad file contains some conditionals near the bottom to slice up the thing into halves and output only one half. So you have to change the if(true) on line 263 into if(false) to get the other half.
Or, if your printer is large enough to print it in one piece, replace all of that with just m();
Also I’m sorry for mixing Dutch and English in the comments and variable names in that file. Almost everyone around me speaks both, so it feels natural to just mix them whenever. But I shouldn’t do that in stuff I plan on sharing
