Hi,
- Windows 11 (24H2 and 25H2)
- Laptop 16 AMD 7040 with and without AMD Radeon™ RX 7700S
- BIOS Version/Date INSYDE Corp. 03.07, 27/08/2025
After working well for a long time, my Gigabyte M32U connected via USB3 (alternate mode) (in port 1) went dark. And it would also not work on the USB port of my AMD Radeon™ RX 7700S.
It all worked again today after two days of trying to figure out why my FW16 did not detect monitors any resolve it.
Now I wonder how I can avoid a repeat of this happening. I have seen some “ monitor glitches happening in the past. Usually a quick restart (with BIOS reset) resolved the issue. But…
I re-installed my AMD Radeon™ RX 7700S (I removed it some time ago because I did not notice and did not need its performance), and the device manager ihowing it “working normally”. But when I connect the monitor to the micro-USB connector on its back, no monitor is detected. The monitor briefly showed a popup with no signal.
When I inserted this Framework micro-USB to HDMI adapter in my FW16 it showed up in the device manager showing it “working normally”. It appeared under the “USB connection managers” as a UCM-UCSO ACPI device”.
However, when I plugged in the HDMI cable, the entry disappeared from the device manager. And no external display was detected. The monitor briefly showed a popup with no signal.
In some in some instances Windows would pop-up titled “ USB” with a message that “Display connection might be limited.” In hindsight this could have been because I was accidentally using port 5. (Which does not support video, need to use 1, 2 or 4.)
What I did to get to the current state (where the USB3 alternate mode video is working but the AMD Radeon™ RX 7700S its USB ports shows no monitor.
All of the above stays the same after:
- Removed all expansion cards (USB-A, 2 x 2.5 Gb/s Ethernet).
- Updating the BIOS to .24.
- Updating windows to 25H2.
- Reinstalling the Framework 16 driver package
- Resetting the BIOS to defaults (F9) and saving (F10) multiple times.
- Disconnecting the battery for 10+ minutes and then reconnecting again (and resetting the BIOS).
Thank you.
Best regards,
Alcindo
(Partial) [System Summary]
Item Value
OS Name Microsoft Windows 11 Pro
Version 10.0.26200 Build 26200
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name XXXXXXX-FW16
System Manufacturer Framework
System Model Laptop 16 (AMD Ryzen 7040 Series)
System Type x64-based PC
System SKU FRAGACCP0G
Processor AMD Ryzen 7 7840HS w/ Radeon 780M Graphics, 3801 Mhz, 8 Core(s), 16 Logical Processor(s)
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Framework
BaseBoard Product FRANMZCP07
BaseBoard Version A7
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United Kingdom
Hardware Abstraction Layer Version = “10.0.26100.1”
Username
Time Zone W. Europe Standard Time
Installed Physical Memory (RAM) 64,0 GB
Total Physical Memory 61,8 GB
Available Physical Memory 53,3 GB
Total Virtual Memory 65,7 GB
Available Virtual Memory 56,8 GB
Page File Space 3,88 GB
Page File C:\pagefile.sys
Kernel DMA Protection On
Virtualisation-based security Running
Virtualisation-based security required security properties
Virtualisation-based security available security properties Base Virtualisation Support, Secure Boot, DMA Protection, UEFI Code Readonly, SMM Security Mitigations 1.0, Mode Based Execution Control
Virtualisation-based security services configured Hypervisor enforced Code Integrity
Virtualisation-based security services running Hypervisor enforced Code Integrity
App Control for Business policy Enforced
App Control for Business user mode policy Off
Automatic Device Encryption Support Elevation Required to View
A hypervisor has been detected. Features required for Hyper-V will not be displayed.
- If there is no information pertaining to your issue or question, please let us know here: Framework | Support https://frame.work/support
