External monitors not recognized Ubuntu 25.10 after updating to kernel 6.17
“Ubuntu 25.10 (Questing Quokka), debian
Updated kernel from linux-modules-6.14.0-33-generic to 6.17.0-5-generic
BIOS: 03.16
Framework Laptop 13 model are you using? Framework Laptop 13 model are you using? AMD Ryzen™ 7040 Series, AMD Ryzen 7 7840U w/ Radeon 780M Graphics (Phoenix, gfx1103).
After updating the kernel from 6.14.0-33-generic to 6.17.0-5-generic, the external monitor is no longer recognized for HDMI and usb-c ports.
sudo dmesg -w output after manually unplugging HDMI-cable and it in again:
```[ 2224.262644] usb 7-1: USB disconnect, device number 11
[ 2224.488541] EXT4-fs (sda1): unmounting filesystem 08f01082-460c-4d05-9d4c-868fe15b188f.
[ 2224.784702] [UFW BLOCK] IN=enx9cbf0d0086f0 OUT= MAC= SRC=192.168.133.123 DST=239.255.255.250 LEN=635 TOS=0x00 PREC=0x00 TTL=1 ID=45031 DF PROTO=UDP SPT=35434 DPT=3702 LEN=615
[ 2224.785168] [UFW BLOCK] IN=docker0 OUT= MAC= SRC=172.17.0.1 DST=239.255.255.250 LEN=635 TOS=0x00 PREC=0x00 TTL=1 ID=41865 DF PROTO=UDP SPT=52273 DPT=3702 LEN=615
[ 2225.650587] ucsi_acpi USBC000:00: unknown error 256
[ 2225.650604] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[ 2226.574847] usb 7-1: new full-speed USB device number 12 using xhci_hcd
[ 2226.735632] usb 7-1: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
[ 2226.735649] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2226.735656] usb 7-1: Product: HDMI Expansion Card
[ 2226.735662] usb 7-1: Manufacturer: Framework
[ 2226.735667] usb 7-1: SerialNumber: 11AD1D009CC7401227250B00
[ 2226.822605] hid-generic 0003:32AC:0002.0016: hiddev0,hidraw0: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:c3:00.4-1/input1
[ 2226.937529] hid-generic 0003:32AC:0002.0017: hiddev0,hidraw0: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:c3:00.4-1/input1```
Gemini A explains as follows, manually unplugging HDMI-cable and reconnecting it again:
Timestamp Log Message Analysis
[ 2224.262644] usb 7-1: USB disconnect, device number 11 The system registers that a device (the Expansion Card) has been disconnected.
[ 2225.650587] ucsi_acpi USBC000:00: unknown error 256 This is the first critical error. ucsi_acpi stands for the USB Type-C Subsystem Interface ACPI driver. An unknown error here suggests a problem in the kernel’s handling of the USB-C port.
[ 2225.650604] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5) This is the second, most serious error. The kernel fails to retrieve the properties of the cable/connection. This process is essential for activating the DisplayPort Alternate Mode over USB-C. The -5 (IO error) indicates that the low-level communication is failing.
[ 2226.735632] usb 7-1: New USB device found, idVendor=32ac, idProduct=0002... The system later recognizes the card, but only as a generic USB device (idProduct=0002 is the Framework HDMI Expansion Card).
[ 2226.735662] usb 7-1: Product: HDMI Expansion Card The card is recognized as “HDMI Expansion Card,” but the video functionality is still not activated due to the preceding ucsi_acpi errors.
Plugging in a usb-c cable directly from monitor in usb-c port also not working, trying to revert to previous kernel but that one is removed from the system, and is also removed from the official repository…
And also adjusting brightness of laptopscreen is not possible, resolution options no longer possible, scaling is worse, etc…
FIX summary (for Framework forum bug report) with help from GROK AI:
Root cause: Installing ROCm 7.0.2 via the noble (Ubuntu 24.04) AMD repo on Ubuntu 25.10 (questing) replaced Ubuntu’s open-source amdgpu driver with workaround proprietary modules. Although this worked fine for kernel 6.14.x after update to 6.17 —> failed to build DKMS modules for kernel 6.17 → amdgpu never loaded → GPU disabled → no brightness, no HDMI/USB-C detection, llvmpipe fallback.
Fix:
sudo apt purge --autoremove 'amdgpu.*' 'rocm.*' 'mesa-amdgpu.*' 'xserver-xorg-video-amdgpu'
sudo rm /etc/apt/sources.list.d/amdgpu* /etc/apt/sources.list.d/rocm*
sudo reboot
→ Ubuntu’s stock amdgpu + Mesa took over → everything works again on 6.17.0-6, no kernel downgrade needed.
Warning: Never use noble AMD/ROCm repos on questing. Wait for official support, hopefully coming soon!
Bug was not kernel 6.17 — it was the incompatible ROCm stack, although it worked with the previous kernel 6.14 with a workaround ;-(
You should not be installing amdgpu-dkms for rocm on Ryzen. The documentation explicitly says to install with --no-dkms.
I did not install with amdgpu-dkms the rocm work around install was with amdgpu --no dkms, and the video-problems were not there untill the update to the newer kernel 6.17.x. So it was working all very well with the previous kernel 6.14.x…
