External sleep indicator 2nd edition (side led)
I made a simple script that colours one of the side leds blue when the framework laptop 13 Intel has been suspended to ram. I have tested the script with Ubuntu 24.10 and Fedora 41. It will probably work with all Intel framework laptops and with all Linux distributions under systemd and kernel 6.11 or later. I hope that someone finds this script useful.
Code:
#!/bin/sh
## location : /usr/lib/systemd/system-sleep/leds
PATH=/sbin:/usr/sbin:/bin:/usr/bin
case "$1" in
    pre)
echo 0 0 100 0 0 0 > /sys/class/leds/chromeos:multicolor:right/multi_intensity
echo 1 > /sys/class/leds/chromeos:multicolor:right/brightness
    post)
echo chromeos-auto > /sys/class/leds/chromeos:multicolor:right/trigger
esac
exit 0
Place this script in:
/usr/lib/systemd/system-sleep/ and name it e.g., leds.
Make the script executable
Code:
sudo cp leds /usr/lib/systemd/system-sleep/
sudo chmod +x  /usr/lib/systemd/system-sleep/leds
Reboot your computer.
Otto
This is really nice, thanks!
For anyone with an AMD laptop, the LED is under /sys/class/leds/chromeos:multicolor:charging/ instead.
