Failed to parse EDID
Void (musl)
Which release?
20240314
Which kernel are you using?
Linux 6.6.52_1
AMD 7040 series with 2.8k Screen
Hello!
I am trying to use dwl v0.6 over wlroots 0.17 with seatd. I have gotten to the point where I can run it with a blank screen and cursor (trackpad working). However, it takes no other input. I use the power button to force out and the terminal shows:
amdgpu: amdgpu_cs_ctx_create2 failed. (-13)
00:00:00.233 [backend/drm/util.c:66] Failed to parse EDID
eDP-1 title
eDP-1 appid
eDP-1 fullscreen
eDP-1 floating
eDP-1 selmon 1
eDP-1 tags 0 1 0 0
eDP-1 layout =
eDP-1 title
eDP-1 appid
eDP-1 fullscreen
eDP-1 floating
eDP-1 selmon 1
eDP-1 tags 0 1 0 0
eDP-1 layout =
eDP-1 title
eDP-1 appid
eDP-1 fullscreen
eDP-1 floating
eDP-1 selmon 1
eDP-1 tags 0 1 0 0
eDP-1 layout =
I am just trying to use the laptop’s built-in screen for now. Any thoughts on what may be going on?
Thanks!
