Fan Control via Rem0o/FanControl on AMD Laptop 13
I tried using the Fan Control Software from Rem0o on my Framework, but it did not detect any fans or fan speeds. Is it a driver issue or a BIOS limitation? If so, why? Is there a reason the fan curve—and therefore the speed—is locked? To be honest, the default fan curve is fine in most cases, but I would like to set it myself because in some situations the case gets very hot while the fan does not run.
