i like that the fans are very aggressively cooling the device, id rather my fans go out than anything else, but it is very loud. i have this thing next to me a lot while im doing stuff i do need this form factor, but just at home at my desk with open backs the sound is getting to me.
are there any drop in replacement fans i could use that don’t sound like a jet engine?
alternately, anyone have ideas for a sound isolated box i could slap on the back of this or put it in? i was thinking just larger high static pressure usb powered fans on the back, and then a cable for the dock, and a cable for power going in. i worry about thermals while it’s closed but it’ll probably be okay?
I have no ideas for a box, but if you install the 7700S dGPU, keep it disabled, and install the latest 4.03 bios, your CPU will stay at 35w or below and you will rarely ever hear the fans.
im open to options, i’ll have to weigh temps vs noise. i do have the framework fan control thing installed but haven’t really seen a way to adjust fan curves more granularly
