My build:
CPU: 7840HS
dGPU: Yes
RAM: 64GB
Storage: 4TB
OS: Ubuntu 22.04 (stock, aside from adding Gnome Tweaks)
So when playing a game or doing a task that utilizes the dGPU, and the laptop is NOT plugged in, I get basically no fan noise. It just seems to work hard and do its job fairly quietly. But when I plug it in (and am doing the same task but now it’s charging), the fans ramp up to 100%
This could probably be tweaked with some fan curve magic via ectool or something, but I was wondering if anyone else noticed this and if it’s normal out of the box
