I have successfully entered several fingerprints but when I attempt to login with them I get this message:
“Authentication required
The login keyring did not get unlocked when you logged into your computer”
and I had to enter my pw by hand, rather defeats the fingerprint idea.
Is there a solution to this?
Laptop Make: Model > Framework: Laptop AB
OS: Ubuntu 22.04 LTS x86_64
Kernel: 5.15.0-35-generic
Shell: bash 5.1.16
DE: GNOME 42.1
WM: Mutter
CPU: 11th Gen Intel i7-1165G7 (8) @ 4.700GHz [111.2°F]
CPU Usage: 4%
Disk (/): 15G / 38G (42%)
GPU: Intel TigerLake-LP GT2 [Iris Xe Graphics]
GPU Driver: i915
Memory: 2800MiB / 15787MiB (17%)
Resolution: 2256x1504
I’d like to be able to use this too, but the login keyring cannot seem to use a fingerprint as an authentication method.
Google “the login keyring did not get unlocked when you logged into your computer” and you’ll see “fixes” which consist of turning it off, but it just asks again whenever you require access to the keyring.
