Firmware update 0.0.4.2 -> Fans not detected despite fans working
Arch
Which kernel are you using?
Linux Elizabeth 6.17.8-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Fri, 14 Nov 2025 06:54:07 +0000 x86_64 GNU/Linux
0.0.4.2
Which Framework Laptop 16 model are you using?
Laptop 16 (AMD Ryzen 7040 Series) (A7)
Since updating the uefi to 0.0.4.2 the laptop complains about fans not being detected and directs me to the GPU install page? I have the storage expansion in the expansion bay.
The fans work fine.
Framework Laptop 16 (AMD Ryzen 7040 Series)
β”‚
β”œβ”€CT4000P3PSSD8:
β”‚     Device ID:          71b677ca0f1bc2c5b804fa1d59e52064ce589293
β”‚     Summary:            NVM Express solid state drive
β”‚     Current version:    P9CR40A
β”‚     Vendor:             Micron/Crucial Technology (PCI:0xC0A9)
β”‚     Serial Number:      2321E6DBA36F
β”‚     GUIDs:              024834f2-5768-5565-b929-e3f57c0fcd69 ← NVME\VEN_C0A9&DEV_540A
β”‚                         6d4f3936-021a-57df-bbd9-493e8f74da7e ← NVME\VEN_C0A9&DEV_540A&SUBSYS_C0A95021
β”‚                         614653d4-7456-5704-a4bc-bc9994adb8cd ← CT4000P3PSSD8
β”‚     Device Flags:       β€’ Internal device
β”‚                         β€’ Updatable
β”‚                         β€’ System requires external power source
β”‚                         β€’ Needs a reboot after installation
β”‚                         β€’ Device is usable for the duration of the update
β”‚                         β€’ Can tag for emulation
β”‚
β”œβ”€Fingerprint Sensor:
β”‚     Device ID:          a6ac74eb9d266e92632936d19976d755b043b55c
β”‚     Summary:            Match-On-Chip fingerprint sensor
β”‚     Current version:    01000334
β”‚     Vendor:             Goodix (USB:0x27C6)
β”‚     Install Duration:   10 seconds
β”‚     Serial Number:      UID05E81A15_XXXX_MOC_B0
β”‚     GUID:               1e8c8470-a49c-571a-82fd-19c9fa32b8c3 ← USB\VID_27C6&PID_609C
β”‚     Device Flags:       β€’ Updatable
β”‚                         β€’ Supported on remote server
β”‚                         β€’ Device stages updates
β”‚                         β€’ Device can recover flash failures
β”‚                         β€’ Signed Payload
β”‚
β”œβ”€HDMI Expansion Card:
β”‚     Device ID:          d787669ee4a103fe0b361fe31c10ea037c72f27c
β”‚     Current version:    3.0.16.106
β”‚     Bootloader Version: 3.0.2.900
β”‚     Vendor:             Framework (USB:0x32AC)
β”‚     Serial Number:      11AD1D009E5C3F12202F0B00
β”‚     GUIDs:              ff59aed5-f8a7-5742-901a-1876d48ea0b5 ← USB\VID_32AC&PID_0002
β”‚                         7cffc965-2ead-5c70-bd62-ce81a42d37fc ← USB\VID_32AC&PID_0002&MODE_FW2
β”‚                         β€’ Unsigned Payload
β”‚
β”œβ”€Hub:
β”‚     Device ID:          b8a2645298053fb62ea03e27feea6c483d3fd27e
β”‚     Current version:    34.4
β”‚     Vendor:             Genesys Logic, Inc. (USB:0x05E3)
β”‚     Install Duration:   9 seconds
β”‚     GUIDs:              50f5a84a-b3a3-50e3-aaa0-bec7853ce9a5 ← USB\VID_05E3&PID_0610&IC_359020&BONDING_78
β”‚                         c4d81c30-cf18-556d-88fa-f21114558764 ← USB\VID_05E3&PID_0610&IC_359020&BONDING_78&RUNMODE_C
β”‚                         f7937235-1a31-52a8-896f-7da42281ff27 ← USB\VID_05E3&PID_0610&VENDOR_GENESYSLOGIC&IC_359020&BONDING_78&PORTNUM_34&VENDORSUP_F90BEF00-53BB-5B38-8D56-7E8844A55516
β”‚                         a786a1df-951f-5f77-81b4-aa07f3d10348 ← USB\VID_05E3&PID_0610&PROJECT_44859ED7-2D4D-5FE8-AA4A-D9A98B8B09F9
β”‚                         β€’ Cryptographic hash verification is available
β”‚
β”œβ”€Laptop 16 Keyboard Module - ANSI:
β”‚     Device ID:          c76174094144e363df0c2b6d9e511ebfce89ed7d
β”‚     Current version:    0.31
β”‚     Vendor:             Framework (HIDRAW:0x32AC)
β”‚     GUID:               bf9a4319-494f-5c88-9637-72f97222cac9 ← HIDRAW\VEN_32AC&DEV_0012
β”‚                         β€’ Updatable
β”‚
β”œβ”€Laptop 16 Numpad Module:
β”‚     Device ID:          e6e8ffd21cef22ff24a6c71ce20499d56d34a73f
β”‚     GUID:               7812afb5-8506-5e90-8881-8f5f9a5b0e75 ← HIDRAW\VEN_32AC&DEV_0014
β”‚                         β€’ Updatable
β”‚
β”œβ”€Ryzen 7 7840HS w/ Radeon 780M Graphics:
β”‚ β”‚   Device ID:          4bde70ba4e39b28f9eab1628f9dd6e6244c03027
β”‚ β”‚   Current version:    0x0a70410a
β”‚ β”‚   Vendor:             AMD
β”‚ β”‚   GUIDs:              2a1df9de-fe02-59c8-8af1-32c8bb011f94 ← CPUID\PRO_0&FAM_19&MOD_74
β”‚ β”‚                       5a4bca32-6547-584f-bb36-920d9adede25 ← CPUID\PRO_0&FAM_19&MOD_74&STP_1
β”‚ β”‚   Device Flags:       β€’ Internal device
β”‚ β”‚
β”‚ β”œβ”€Radeon 780M Graphics:
β”‚ β”‚     Device ID:        ab66dd4442bdf3ad5d4101887804658d6045632a
β”‚ β”‚     Summary:          AMD AMD_PHOENIX_GENERIC
β”‚ β”‚     Current version:  1
β”‚ β”‚     Vendor:           AMD (PCI:0x1002)
β”‚ β”‚     GUID:             4a1501b7-b500-5255-9d9c-41d652a4d5bc ← AMD\113-PHXGEN
β”‚ β”‚                       β€’ Can tag for emulation
β”‚ β”‚
β”‚ β”œβ”€Secure Processor:
β”‚ β”‚     Device ID:        c54ab0237d7a8db8c717b68e0be78e4374a2a079
β”‚ β”‚     Summary:          AGESA PhoenixPI-FP8-FP7 1.2.0.0c
β”‚ β”‚     Current version:  00.2d.00.86
β”‚ β”‚     Bootloader Version: 00.2d.00.86
β”‚ β”‚     Vendor:           AMD (PCI:0x1022)
β”‚ β”‚     GUID:             9eb6a793-7f97-5fb5-b49c-139d2ce3ee46 ← PCI\VEN_1022&DEV_15C7
β”‚ β”‚
β”‚ β”œβ”€System Management Unit (SMU):
β”‚ β”‚     Device ID:        db0330716216c629bb2c07256e5d018f499eb6ce
β”‚ β”‚     Summary:          Microcontroller used within CPU/APU program 0
β”‚ β”‚     Current version:  76.96.0
β”‚ β”‚     Vendor:           AMD
β”‚ β”‚     GUID:             3ac3159e-6eef-5f6b-bc8d-67686b238747 ← /sys/devices/platform/AMDI0009:00
β”‚ β”‚
β”‚ └─TPM:
β”‚       Device ID:        1d8d50a4dbc65618f5c399c2ae827b632b3ccc11
β”‚       Current version:  6.4.1.383
β”‚       Vendor:           Microsoft (TPM:MSFT)
β”‚       GUIDs:            2a65d4b6-60a0-5e8c-acfa-d86cc3cbe4c3 ← TPM\VEN_MSFT&DEV_0001
β”‚                         31a7bb1b-f5e1-53ff-b0e5-8692a21caed6 ← TPM\VEN_MSFT&MOD_Pluton.TPM.A
β”‚                         5bea8d58-c840-513e-a5ad-0184cbaa9821 ← TPM\VEN_MSFT&DEV_0001&VER_2.0
β”‚                         e02519c6-9139-5de8-89d4-9dca2f5c3b66 ← TPM\VEN_MSFT&MOD_Pluton.TPM.A&VER_2.0
β”‚
β”œβ”€SSD 980 PRO 2TB:
β”‚     Device ID:          3743975ad7f64f8d6575a9ae49fb3a8856fe186f
β”‚     Current version:    5B2QGXA7
β”‚     Vendor:             Samsung (PCI:0x144D)
β”‚     Serial Number:      S69ENX0TC09596T
β”‚     GUIDs:              bec63ed7-a95f-54fe-b8cc-8e9fee64ba5a ← NVME\VEN_144D&DEV_A80A
β”‚                         310f81b5-6fce-501e-acfb-487d10501e78 ← NVME\VEN_144D&DEV_A80A&SUBSYS_144DA801
β”‚                         c8bffd05-1744-5cdd-ad4d-0fbc3b20e3c2 ← Samsung SSD 980 PRO 2TB
β”‚                         β€’ Updatable
β”‚
└─System Firmware:
  β”‚   Device ID:          7010981714ee5c9258de42216cae163ef272c7ab
  β”‚   Summary:            UEFI System Resource Table device (Updated via capsule-on-disk)
  β”‚   Current version:    0.0.4.2
  β”‚   Minimum Version:    0.0.3.5
  β”‚   Vendor:             Framework (DMI:INSYDE Corp.)
  β”‚   Update State:       Success
  β”‚   GUID:               6ae76af1-c002-5d64-8e18-658d205acf34
  β”‚                       β€’ Updatable
  β”‚   Device Requests:    β€’ Message
  β”‚
  β”œβ”€Platform Key:
  β”‚     Device ID:        6924110cde4fa051bfdc600a60620dc7aa9d3c6a
  β”‚     Summary:          UEFI Platform Key
  β”‚     Current version:  2024
  β”‚     Vendor:           Unknown
  β”‚     GUID:             5451f72c-f83c-5496-84ff-61e64ae398ab ← UEFI\CRT_2C31E1EB92664370A58B2217FF12E8D0D12CAE6F
  β”‚
  β”œβ”€UEFI Key Exchange Key:
  β”‚ β”‚   Device ID:        2a4c23bfb79b5dabe474cb7b1b3e604645d6f9c6
  β”‚ β”‚
  β”‚ β”œβ”€KEK CA:
  β”‚ β”‚     Device ID:      b7a1d3d90faa1f6275d9a98da4fb3be7118e61c7
  β”‚ β”‚     Current version: 2011
  β”‚ β”‚     Vendor:         Microsoft (UEFI:Microsoft)
  β”‚ β”‚     GUIDs:          814e950f-1449-566a-a190-42c9d3a3a2df ← UEFI\VENDOR_Microsoft&NAME_Microsoft-KEK-CA
  β”‚ β”‚                     dfa66406-6568-5bdf-bb8e-b53ddb4be4cf ← UEFI\CRT_9F402B1CC0243CBEDC58A525789816CCCA7687A9
  β”‚ β”‚                     β€’ Updatable
  β”‚ β”‚                     β€’ Needs a reboot after installation
  β”‚ β”‚                     β€’ Device is usable for the duration of the update
  β”‚ β”‚                     β€’ Signed Payload
  β”‚ β”‚
  β”‚ └─Key Exchange Key:
  β”‚       Device ID:      7227626d9209595851b3840e3d626601a375ce2d
  β”‚       Update Error:   No vendor ID set
  β”‚       GUID:           ad4972b1-c98e-5ca7-9fd4-257d33e2ad99 ← UEFI\CRT_2E9F57E1A49A6593D07E7D5383489A6370EFA016
  β”‚                       β€’ Updatable
  β”‚
  β”œβ”€UEFI Signature Database:
  β”‚ β”‚   Device ID:        0352a8acc949c7df21fec16e566ba9a74e797a97
  β”‚ β”‚
  β”‚ β”œβ”€Database Key:
  β”‚ β”‚     Device ID:      0e3b4bfc8e1d26fa79855e17c4a13e4f4ddf316f
  β”‚ β”‚     Current version: 2024
  β”‚ β”‚     Update Error:   No vendor ID set
  β”‚ β”‚     GUID:           73701685-efe6-5d5f-a9a2-1b5b06b1f6d1 ← UEFI\CRT_9552667ABDC43FE2CD1E6A67F2C83693B5D7E2C4
  β”‚ β”‚
  β”‚ β”œβ”€Option ROM UEFI CA:
  β”‚ β”‚     Device ID:      92120fc1a625f725901333cbfec152b8d6e42d43
  β”‚ β”‚     Current version: 2023
  β”‚ β”‚     GUIDs:          ca4668d9-734f-5b2b-aae8-8120b196f659 ← UEFI\VENDOR_Microsoft&NAME_Microsoft-Option-ROM-UEFI-CA
  β”‚ β”‚                     965d1919-0e18-5b63-9ebd-e5d122cd11df ← UEFI\CRT_F45B559FC1C60F31B3071021298D5ED7D77280B0
  β”‚ β”‚
  β”‚ β”œβ”€UEFI CA:
  β”‚ β”‚     Device ID:      5bc922b7bd1adb5b6f99592611404036bd9f42d0
  β”‚ β”‚     GUIDs:          26f42cba-9bf6-5365-802b-e250eb757e96 ← UEFI\VENDOR_Microsoft&NAME_Microsoft-UEFI-CA
  β”‚ β”‚                     308281c7-d0c5-52e0-8c1a-810540de03df ← UEFI\CRT_7CD7437C555F89E7C2B50E21937E420C4E583E80
  β”‚ β”‚                     β€’ Supported on remote server
  β”‚ β”‚
  β”‚ └─Windows Production PCA:
  β”‚       Device ID:      ad7e00ec37f005ae10492bdb7f73aef0d2e20488
  β”‚       GUIDs:          675d2184-6c9a-59f1-a6f1-3c229b5dbb79 ← UEFI\VENDOR_Microsoft&NAME_Microsoft-Windows-Production-PCA
  β”‚                       0611d85d-99a4-5c50-8c17-fc5196226f85 ← UEFI\CRT_1A8B6903D64CC9AD09D12FCB355663A458A09EF0
  β”‚                       β€’ Updatable
  β”‚
  └─UEFI dbx:
        Device ID:        362301da643102b9f38477387e2193e57abaa590
        Summary:          UEFI revocation database
        Current version:  20250902
        Minimum Version:  20250902
        Install Duration: 1 second
        GUIDs:            3bf2bb02-b0b8-5013-afb6-c9ebde785306 ← UEFI\CRT_CA23D6026B02CEA851A46A39BE5C7F931BAE2D0175F7E59DE791B2238833F2D8&ARCH_X64
                          f8ba2887-9411-5c36-9cee-88995bb39731 ← UEFI\CRT_A1117F516A32CEFCBA3F2D1ACE10A87972FD6BBE8FE0D0B996E09E65D802A503&ARCH_X64
                          β€’ Updatable
                          β€’ Only version upgrades are allowed
                          β€’ Signed Payload
I had this happen, once, on a cool boot with my 16 in my backpack overnight. After turning it off and back on again, as one does, it didn’t come back up and it hasn’t shown up again.
What does your OS say?
Nothing no problem what so ever. The fans work just fine. The warning shows up every boot though.
Downgrading to 3.07 made the warning disappear.
I also opened issues on their github:
