Windows 11 Framework 16
I recently took out my GPU to clean one of the fans. However, now I am getting a “Fans not detected” on boot and my laptop doesn’t spin them up under load. The GPU is able to be utilized fine, but for some reason the fans just aren’t detected. I don’t think it’s a connection issue because I checked the fan connections and both are secure. My fans were working perfectly before this so this is confusing to me.
What’s the next course of action here? It would be nice if there was same way to see where the problem was, whether it’s with just 1 fan or both.
James3
February 1, 2026, 4:22pm
2
The fans are detected by the EC.
The connection between the EC and the Fans is over the “interposer”. The small connector between the mainboard and the expansion bay.
It would probably be a good idea to open up the laptop, remove the interposer, and check that it is clean and no dust or something has got in, that might make some of the pins not connect. Check the interpose, and also the pads on the mainboard and expansion bay board.
If everything looks good, put the interposer back in, tighten all 6 screws and try again.
There is a tool, called “ectool” that you can use to force the fans on, and see their RPM.
I did that and still the same problem :(. So the interposer appears to be just fine.
And attempting to force the fans on did not work, they did not start at all.
James3
February 1, 2026, 5:27pm
4
Can you get any log output from “ectool console” while trying to force the fans on and see their RPM.
It might give some indication as to why the fans are not working.
I should’ve clarified: I’m on windows so I’m using Framework Control to try force my fans on.
Yes and I didn’t find any help from it
Vikram
February 1, 2026, 8:53pm
8
Point being that this appears to be an issue with the Framework 16 AMD laptops (which model do you have?).
One thing to try appears to be seeing if the issue occurs with the mid-plate removed (as noted by two people in the 7040 Github thread.
See the Github issues in links below and add your experience to the relevant one:
opened 11:48AM - 20 Nov 25 UTC
Laptop 16 AMD Ryzen 7040
4.02
## Device Information
### System Model or SKU
Framework Laptop 16 (AMD Ryzen™ … 7040 Series)
### BIOS VERSION
`0.0.4.2` or `4.0.2` or `04.02`
### DIY Edition information
If you are experiencing an issue on a DIY system, Please also fill out the memory and storage devices you are using.
Memory: Stock
Storage: SSD 980 PRO 2TB
### Standalone Operation
Are you running your mainboard as a standalone device. Is standalone mode enabled in the BIOS?
- [ ] Yes
- [x] No
## Describe the bug
Since updating the uefi to 0.0.4.2 the laptop complains about fans not being detected and directs me to the GPU install page? I have the storage expansion in the expansion bay.
Note: It would be nice to add a table of all prior uefi versions and their respective cab file download links on the uefi update page for ease of downgrades after failures/regressions: https://fwupd.org/lvfs/devices/work.frame.Laptop16.Ryzen7040.BIOS.firmware
## Steps To Reproduce
Steps to reproduce the behavior:
1. Install the firmware update and reboot.
## Expected behavior
No fan error should be displayed.
## Screenshots
## Operating System (please complete the following information):
- OS/Distribution: arch
- Version: Rolling
- Linux Kernel Version: `Linux Elizabeth 6.17.8-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Fri, 14 Nov 2025 06:54:07 +0000 x86_64 GNU/Linux`
## Additional context
Framework Laptop 16 (AMD Ryzen 7040 Series)
├─CT4000P3PSSD8:
│ Device ID: 71b677ca0f1bc2c5b804fa1d59e52064ce589293
│ Summary: NVM Express solid state drive
│ Current version: P9CR40A
│ Vendor: Micron/Crucial Technology (PCI:0xC0A9)
│ Serial Number: 2321E6DBA36F
│ GUIDs: 024834f2-5768-5565-b929-e3f57c0fcd69 ← NVME\VEN_C0A9&DEV_540A
│ 6d4f3936-021a-57df-bbd9-493e8f74da7e ← NVME\VEN_C0A9&DEV_540A&SUBSYS_C0A95021
│ 614653d4-7456-5704-a4bc-bc9994adb8cd ← CT4000P3PSSD8
│ Device Flags: • Internal device
│ • Updatable
│ • System requires external power source
│ • Needs a reboot after installation
│ • Device is usable for the duration of the update
│ • Can tag for emulation
├─Fingerprint Sensor:
│ Device ID: a6ac74eb9d266e92632936d19976d755b043b55c
│ Summary: Match-On-Chip fingerprint sensor
│ Current version: 01000334
│ Vendor: Goodix (USB:0x27C6)
│ Install Duration: 10 seconds
│ Serial Number: UID05E81A15_XXXX_MOC_B0
│ GUID: 1e8c8470-a49c-571a-82fd-19c9fa32b8c3 ← USB\VID_27C6&PID_609C
│ Device Flags: • Updatable
│ • Supported on remote server
│ • Device stages updates
│ • Device can recover flash failures
│ • Signed Payload
├─HDMI Expansion Card:
│ Device ID: d787669ee4a103fe0b361fe31c10ea037c72f27c
│ Current version: 3.0.16.106
│ Bootloader Version: 3.0.2.900
│ Vendor: Framework (USB:0x32AC)
│ Serial Number: 11AD1D009E5C3F12202F0B00
│ GUIDs: ff59aed5-f8a7-5742-901a-1876d48ea0b5 ← USB\VID_32AC&PID_0002
│ 7cffc965-2ead-5c70-bd62-ce81a42d37fc ← USB\VID_32AC&PID_0002&MODE_FW2
│ • Unsigned Payload
├─Hub:
│ Device ID: b8a2645298053fb62ea03e27feea6c483d3fd27e
│ Current version: 34.4
│ Vendor: Genesys Logic, Inc. (USB:0x05E3)
│ Install Duration: 9 seconds
│ GUIDs: 50f5a84a-b3a3-50e3-aaa0-bec7853ce9a5 ← USB\VID_05E3&PID_0610&IC_359020&BONDING_78
│ c4d81c30-cf18-556d-88fa-f21114558764 ← USB\VID_05E3&PID_0610&IC_359020&BONDING_78&RUNMODE_C
│ f7937235-1a31-52a8-896f-7da42281ff27 ← USB\VID_05E3&PID_0610&VENDOR_GENESYSLOGIC&IC_359020&BONDING_78&PORTNUM_34&VENDORSUP_F90BEF00-53BB-5B38-8D56-7E8844A55516
│ a786a1df-951f-5f77-81b4-aa07f3d10348 ← USB\VID_05E3&PID_0610&PROJECT_44859ED7-2D4D-5FE8-AA4A-D9A98B8B09F9
│ • Cryptographic hash verification is available
├─Laptop 16 Keyboard Module - ANSI:
│ Device ID: c76174094144e363df0c2b6d9e511ebfce89ed7d
│ Current version: 0.31
│ Vendor: Framework (HIDRAW:0x32AC)
│ GUID: bf9a4319-494f-5c88-9637-72f97222cac9 ← HIDRAW\VEN_32AC&DEV_0012
│ • Updatable
├─Laptop 16 Numpad Module:
│ Device ID: e6e8ffd21cef22ff24a6c71ce20499d56d34a73f
│ GUID: 7812afb5-8506-5e90-8881-8f5f9a5b0e75 ← HIDRAW\VEN_32AC&DEV_0014
│ • Updatable
├─Ryzen 7 7840HS w/ Radeon 780M Graphics:
│ │ Device ID: 4bde70ba4e39b28f9eab1628f9dd6e6244c03027
│ │ Current version: 0x0a70410a
│ │ Vendor: AMD
│ │ GUIDs: 2a1df9de-fe02-59c8-8af1-32c8bb011f94 ← CPUID\PRO_0&FAM_19&MOD_74
│ │ 5a4bca32-6547-584f-bb36-920d9adede25 ← CPUID\PRO_0&FAM_19&MOD_74&STP_1
│ │ Device Flags: • Internal device
│ ├─Radeon 780M Graphics:
│ │ Device ID: ab66dd4442bdf3ad5d4101887804658d6045632a
│ │ Summary: AMD AMD_PHOENIX_GENERIC
│ │ Current version: 1
│ │ Vendor: AMD (PCI:0x1002)
│ │ GUID: 4a1501b7-b500-5255-9d9c-41d652a4d5bc ← AMD\113-PHXGEN
│ │ • Can tag for emulation
│ ├─Secure Processor:
│ │ Device ID: c54ab0237d7a8db8c717b68e0be78e4374a2a079
│ │ Summary: AGESA PhoenixPI-FP8-FP7 1.2.0.0c
│ │ Current version: 00.2d.00.86
│ │ Bootloader Version: 00.2d.00.86
│ │ Vendor: AMD (PCI:0x1022)
│ │ GUID: 9eb6a793-7f97-5fb5-b49c-139d2ce3ee46 ← PCI\VEN_1022&DEV_15C7
│ ├─System Management Unit (SMU):
│ │ Device ID: db0330716216c629bb2c07256e5d018f499eb6ce
│ │ Summary: Microcontroller used within CPU/APU program 0
│ │ Current version: 76.96.0
│ │ Vendor: AMD
│ │ GUID: 3ac3159e-6eef-5f6b-bc8d-67686b238747 ← /sys/devices/platform/AMDI0009:00
│ └─TPM:
│ Device ID: 1d8d50a4dbc65618f5c399c2ae827b632b3ccc11
│ Current version: 6.4.1.383
│ Vendor: Microsoft (TPM:MSFT)
│ GUIDs: 2a65d4b6-60a0-5e8c-acfa-d86cc3cbe4c3 ← TPM\VEN_MSFT&DEV_0001
│ 31a7bb1b-f5e1-53ff-b0e5-8692a21caed6 ← TPM\VEN_MSFT&MOD_Pluton.TPM.A
│ 5bea8d58-c840-513e-a5ad-0184cbaa9821 ← TPM\VEN_MSFT&DEV_0001&VER_2.0
│ e02519c6-9139-5de8-89d4-9dca2f5c3b66 ← TPM\VEN_MSFT&MOD_Pluton.TPM.A&VER_2.0
│ • Signed Payload
├─SSD 980 PRO 2TB:
│ Device ID: 3743975ad7f64f8d6575a9ae49fb3a8856fe186f
│ Current version: 5B2QGXA7
│ Vendor: Samsung (PCI:0x144D)
│ Serial Number: S69ENX0TC09596T
│ GUIDs: bec63ed7-a95f-54fe-b8cc-8e9fee64ba5a ← NVME\VEN_144D&DEV_A80A
│ 310f81b5-6fce-501e-acfb-487d10501e78 ← NVME\VEN_144D&DEV_A80A&SUBSYS_144DA801
│ c8bffd05-1744-5cdd-ad4d-0fbc3b20e3c2 ← Samsung SSD 980 PRO 2TB
│ • Updatable
│ • Signed Payload
└─System Firmware:
│ Device ID: 7010981714ee5c9258de42216cae163ef272c7ab
│ Summary: UEFI System Resource Table device (Updated via capsule-on-disk)
│ Current version: 0.0.4.2
│ Minimum Version: 0.0.3.5
│ Vendor: Framework (DMI:INSYDE Corp.)
│ Update State: Success
│ GUID: 6ae76af1-c002-5d64-8e18-658d205acf34
│ • Updatable
│ Device Requests: • Message
├─Platform Key:
│ Device ID: 6924110cde4fa051bfdc600a60620dc7aa9d3c6a
│ Summary: UEFI Platform Key
│ Current version: 2024
│ Vendor: Unknown
│ GUID: 5451f72c-f83c-5496-84ff-61e64ae398ab ← UEFI\CRT_2C31E1EB92664370A58B2217FF12E8D0D12CAE6F
├─UEFI Key Exchange Key:
│ │ Device ID: 2a4c23bfb79b5dabe474cb7b1b3e604645d6f9c6
│ ├─KEK CA:
│ │ Device ID: b7a1d3d90faa1f6275d9a98da4fb3be7118e61c7
│ │ Current version: 2011
│ │ Vendor: Microsoft (UEFI:Microsoft)
│ │ GUIDs: 814e950f-1449-566a-a190-42c9d3a3a2df ← UEFI\VENDOR_Microsoft&NAME_Microsoft-KEK-CA
│ │ dfa66406-6568-5bdf-bb8e-b53ddb4be4cf ← UEFI\CRT_9F402B1CC0243CBEDC58A525789816CCCA7687A9
│ │ • Updatable
│ │ • Needs a reboot after installation
│ │ • Device is usable for the duration of the update
│ │ • Signed Payload
│ └─Key Exchange Key:
│ Device ID: 7227626d9209595851b3840e3d626601a375ce2d
│ Update Error: No vendor ID set
│ GUID: ad4972b1-c98e-5ca7-9fd4-257d33e2ad99 ← UEFI\CRT_2E9F57E1A49A6593D07E7D5383489A6370EFA016
│ • Updatable
│ • Signed Payload
├─UEFI Signature Database:
│ │ Device ID: 0352a8acc949c7df21fec16e566ba9a74e797a97
│ ├─Database Key:
│ │ Device ID: 0e3b4bfc8e1d26fa79855e17c4a13e4f4ddf316f
│ │ Current version: 2024
│ │ Update Error: No vendor ID set
│ │ GUID: 73701685-efe6-5d5f-a9a2-1b5b06b1f6d1 ← UEFI\CRT_9552667ABDC43FE2CD1E6A67F2C83693B5D7E2C4
│ │ • Updatable
│ ├─Option ROM UEFI CA:
│ │ Device ID: 92120fc1a625f725901333cbfec152b8d6e42d43
│ │ Current version: 2023
│ │ GUIDs: ca4668d9-734f-5b2b-aae8-8120b196f659 ← UEFI\VENDOR_Microsoft&NAME_Microsoft-Option-ROM-UEFI-CA
│ │ 965d1919-0e18-5b63-9ebd-e5d122cd11df ← UEFI\CRT_F45B559FC1C60F31B3071021298D5ED7D77280B0
│ │ • Updatable
│ ├─UEFI CA:
│ │ Device ID: 5bc922b7bd1adb5b6f99592611404036bd9f42d0
│ │ GUIDs: 26f42cba-9bf6-5365-802b-e250eb757e96 ← UEFI\VENDOR_Microsoft&NAME_Microsoft-UEFI-CA
│ │ 308281c7-d0c5-52e0-8c1a-810540de03df ← UEFI\CRT_7CD7437C555F89E7C2B50E21937E420C4E583E80
│ │ • Updatable
│ │ • Supported on remote server
│ └─Windows Production PCA:
│ Device ID: ad7e00ec37f005ae10492bdb7f73aef0d2e20488
│ GUIDs: 675d2184-6c9a-59f1-a6f1-3c229b5dbb79 ← UEFI\VENDOR_Microsoft&NAME_Microsoft-Windows-Production-PCA
│ 0611d85d-99a4-5c50-8c17-fc5196226f85 ← UEFI\CRT_1A8B6903D64CC9AD09D12FCB355663A458A09EF0
│ • Updatable
│ • Signed Payload
└─UEFI dbx:
Device ID: 362301da643102b9f38477387e2193e57abaa590
Summary: UEFI revocation database
Current version: 20250902
Minimum Version: 20250902
Install Duration: 1 second
GUIDs: 3bf2bb02-b0b8-5013-afb6-c9ebde785306 ← UEFI\CRT_CA23D6026B02CEA851A46A39BE5C7F931BAE2D0175F7E59DE791B2238833F2D8&ARCH_X64
f8ba2887-9411-5c36-9cee-88995bb39731 ← UEFI\CRT_A1117F516A32CEFCBA3F2D1ACE10A87972FD6BBE8FE0D0B996E09E65D802A503&ARCH_X64
• Updatable
• Only version upgrades are allowed
• Signed Payload
Relevant forum post: https://community.frame.work/t/firmware-update-0-0-4-2-fans-not-detected-despite-fans-working/78077
opened 02:51PM - 29 Jan 26 UTC
### Device Information
Framework Laptop 16 (AMD Ryzen™ AI 300 Series)
### BIOS… VERSION
3.04
Memory: Crucial 2x16Gb CT2K16G56C46S5
Storage: Reproducible without Storage!
### Standalone Operation (Laptop Only)
- [ ] Yes
- [x] No
## Describe the bug
After the laptop was turned off for a while, the system shows a warning on boot "**Fans not detected**". But the fans are clearly working when booting though the error and are also detected in the BIOS menu.
Interestingly, booting "warm", so restarting the PC within a shorter time after shutdown does not trigger the error for me, maybe Windows does some fast startup magic or some charge/state is lost if the laptop is turned off for a long time.
I am in a long E-Mail chain with support and already got one mainboard replacement and then a full core laptop replacement and the error still shows up! All memtests pass, never got any crash whatsoever once the system was up and running.
This seems to be related to the unsolved #131 , but here for the Ryzen AI series. Also here is another case:
https://community.frame.work/t/fans-not-detected-in-ai-300-series/79696
**What are the chances this is firmware related? Battery, RAM? I'd be very happy to find answers here!**
1. Boot cold.
2. Get error.
## Screenshots
See #131 .
- Reproducible without an SSD installed and any OS installed
Update:
I’ve contacted support to see what they have to say and I’m fairly sure at this point it’s a hardware issue, as I tried downgrading my BIOS to see if that helped at all and it didn’t. And since the interposer is seemingly working fine (as I can use the dgpu), and the fan cables have no visible problems, I’m unsure where to proceed from here.
Yeah I think my issue is most likely a hardware one as my fans aren’t even working within the OS
Dumping some info here gotten from the framework_tool util
>framework_tool --expansion-bay
Expansion Bay
Enabled: true
No fault: true
Door closed: true
Board: DualInterposer
Serial Number: FRAKMBCPA3410600BE Config: Pcie8x1
Vendor: GpuAmdR23M
Expansion Bay EEPROM
Valid: true
HW Version: 8.0
>framework_tool --thermal
F75303_Local: 47 C
F75303_CPU: 45 C
F75303_DDR: 48 C
APU: 47 C
dGPU VR: 60 C
dGPU VRAM: 62 C
dGPU AMB: 62 C
dGPU temp: 65 C
Fan Speed: 0 RPM
Fan Speed: 0 RPM
