I’m just about to buy a Framework13 but I’m struggling to chose between the AMD 7640u or the AMD AI 5 340 (budget is kinda low, which is why I’m not going into the AI 7 or AI 9). I’ve tried to read a couple of questions on the forum but haven’t find anything decisive helping me make my decision. I’ll be running Ubuntu 24.04, with 16gb of ram (planning on going to 32gb), with 1Tb of ssd and the 2.8k display for the 120Hz refresh rate. I’m mostly doing some lightweight python development, with docker and postgres databases.
I’ve found a post saying that the 7640u is probably a better bet as it was around for longer and most problems have had an answer to, but at the same time I’ve found post as recent as autumn 2025 raising problems with the 7640u. Is the ~200$ more for the AI 5 340 worth, or is the 7640u more than enough?
Hello! I’m not sure if I’m too late, but speaking purely from my personal experience, the 7640U is a perfectly capable CPU for lightweight development work. I’m writing from my FW 13 with a 7640U now, in fact, and I’ve been using this system for Rust development without issue. I believe you’ll get significantly more mileage out of the AI 5 340, but it’s up to you to decide whether to spend the extra money. I personally think you’ll be happy with either, at least in terms of performance.
Since you mentioned using Ubuntu 24.04, I’m inclined to suggest the 7640U over the AI 5 340. I don’t know for sure, but I’m guessing that your OS lacks support for the AI 5 340. As a longtime Debian user myself, I’m very familiar with the woes of trying to use too-new hardware on an older kernel, Mesa version, etc. When I got an RDNA4 GPU for my desktop, I had to switch away from Debian. This has caused me headaches and made me sad. My FW 13 with its 7640U, on the other hand, has worked quite well on Debian, and I have been quite happy with my choice. Slightly older hardware has its advantages! I suspect you, too, might be happy with the 7640U and sad with the AI 5 340, but I haven’t actually checked compatibility. If you opt for the latter chip, please do see if it will actually work with your OS! (I don’t have a great source to link; when I was shopping for RDNA4, I stumbled on a very helpful Level1Techs forum post by Wendell that directly said what kernel and Mesa versions I needed. I made my purchase anyway, but predictably, I had an unhappy time on Debian.)
You were not too late! Haven’t ordered yet, and also tumbled upon two reddit posts regarding the 7640u; one talking about its pleasant experience (also on ubuntu 24.04), and the other comparing with the AI 5 340 and the expected usage, which as you suggest the 7640u will probably be plenty enough for me!
I will most likely go with the 7640u just to save a couple bucks, as it seems really close to the base AI 5 340 on a lot of points.
Oh, my. Yep, I should have done more research before speaking. @Benobo I apologize; I misspoke before. I have now done my due diligence.
I didn’t realize the AI 5 340 was Krackan Point, a budget line toned way, way down from the likes of the fantastic Strix Point. I would not personally pay more for Krackan Point than Phoenix; that seems like a strange and backwards price structure to me. I’m not sure if the FW 13 with Krackan Point includes other upgrades as part of that $899 price tag. Unless I’m missing some other upgrades, though, I would pick the 7640U + 2.8K display for the same price or save the money by buying the 2.2K display for $769 (depending on personal priorities).
I completely agree with you about the iGPU. The 7640U has 8 CUs of RDNA 3, whereas the 340 has 4 CUs of RDNA 3.5. Yikes.
I haven’t found any benchmarks that (a) are relevant and (b) I’m inclined to trust. Phoronix has the best test coverage I’ve found for the AI 5 340, but its configuration ran around 17 Watts for code compilation, whereas the FW 13 should allow about 30 W, I believe. The only conclusion I am comfortable drawing is therefore, “The FW 13 will outperform Phoronix’s benchmarks.”
Seeing the core config and base clock, I’m not confident that the AI 5 340 would actually perform much better than the 7640U for software development. I imagine it’s an improvement in single-threaded tasks, but between the low base clocks and the usage of 3x Zen 5c cores, I’m skeptical of multithreaded performance improvements. I have seen some unrelated multi-core benchmarks claiming quite small performance differences between the two. For instance, Passmark claims the 340 is roughly 5% ahead in single-core performance and 5% behind in multi-core performance; to me, that’s a wash. I’m very skeptical of the value proposition of the AI 5 340 at $130 more.
As for compatibility, I do see that FW recommends kernel version 6.15 or newer for the AI 5 300 line and that Ubuntu 24.04.4 ships kernel version 6.17 and Mesa 25.2. It seems Ubuntu ships significant kernel and Mesa version upgrades in its LTS release channels; I wasn’t aware of this. I believe you should be fine on compatibility either way.
You are very welcome! I somehow didn’t see your reply before I posted just above. I think you’re making the right call and will be quite happy! Honestly, the fact that I didn’t even realize the AI 5 340 was Krackan Point tells you that I never felt any desire to consider upgrading from my 7640U.
Thank you again for all your inputs @edev! I’m not as familiar with hardware and it was all very much appreciated! I’ve finally ordered the 7640u Can’t wait to be on this machine!
