Framework 11th gen bios battery compatibility
I have a framework 11th gen with bios 3.06 and I am thinking about getting the new high-capacity 61Wh battery, do i need to update to 3.19 or newer BIOS to use at all or just take advantage of the increased capacity.
I’m having trouble getting my BIOS to update, and I need to replace the battery soon.
Their exist additional battery protection in later bios version. You may experience significant premature ware on earlier bios versions, and potentially failure ( the spicy pillow kind ).
/Zoe
There are instructions for BIOS update without battery, no need to rush
