Framework 13 1280p SteamVR
Framework 13 1280P Intel
Running Windows 11
I’m getting an error every time I try and use SteamVR with the laptop.
Error 499
Couldn’t set up a video encoder. Your GPU may not be supported, or you may need to update your computer’s graphics driver. (499)
I know it is recommended to use a dedicated GPU for this but I do not have anything but this right now. Is there a way to make this work? My drivers are all updated, I can play games just fine on my laptop just wanted to have VR adventures with my Metaquest 3s. Is my Framework just not an option for this?
-A desperate plea for help
Brenden
maybe allocate more memory to the GPU in the bios?? IIRC default is 512mb but there is a setting that raises that maximum to 2gb or 4gb if you have >24gb of ram
