Framework 13 Fn Lock permanently enabled
Hello,
I absolutely love my framework 13, but recently I have been having an issue where sometimes when the laptop boots, it has fn lock permanently enabled. This seems like a really weird issue, and I was wondering if anyone else was having it or if there was a solution?
Thanks,
Yash
Hi, did you try the Fn+ESC to disable it?
What operating system are you using?
Does it happen only at certain times?
What generation of laptop are you using?
Hi, more info. I am using arch linux, and this issue appears to also occur at random times while I am using my laptop. The only solution is to reboot the computer, which will disable fn lock. Using the fn + esc isnt disabling fn lock.
Sounds like this issue: Fn Key / Media Keys Broken in Arch - #4 by DHowett
