Framework 13 pro XPG Mars 970 Plus heatsink?
Going to install ssd it comes with “thin” heatsink should i install this with ssd or not?
I did install the ssd without the top heat sink.
You shouldn’t install according to the framework guide Important notice for installing double-sided SSDs & avoiding SSD heat-spreaders which says “Please avoid using the optional heat-spreader if included in the box”
