Framework 13 Ryzen 7040
Whenever i connect any USB webcam i cannot open camera app. camera setting. cannot get it to work with any web applications. it freezes solid many applications. cannot restart normally have to long press the power button.
Pissed i have to do work on a brand new computer… and trying not to get screwed over by geek squad. any help would be monstrously appreciated.
this is about to be the last time i support this brand if not.
This category is for reviews, discussions, recommendations, and benchmarks related to the Framework Laptop 13.
When creating a topic, use a product tag (and a secondary tag if applicable).
For Linux-related issues, use the “Framework Laptop 13 Linux” subcategory.
If you have a hardware/software issue, please post it under “Community Support” category.
What OS and webcam(s) are you using?
So I am running Windows 11 and I two Logitech c920s and a 4K ONN webcam but I just tried something and it worked and I will post that here below this comment
I checked the setup page when doom scrolling framework website. I wasnt told about the extra downloads for reassembled. I scrolled to the amd ryzen section and downloaded and updated from both links. Then it worked
Im not super computer literate so i was in the dark and nothing on the box told me to go here and do this.
It’s cool - Framework is made for the tinkerer and the explorer. You’ll find you’ll be learning a lot about computers through your purchasing of one. But yes, ALWAYS try to make sure your drivers and BIOS (Basic Input/Output System) are up to date. A lot of the time such issues are caused by conflicts between hardware and old drivers. This is especially true for peripherals like USB webcams.
Awesome job getting down to the root of the problem!
