I just noticed the touchpad module wasn’t seated correctly and saw that a bulge was pushing the bottom of the mainboard upward. I quickly removed all the modules and the mainboard, then discovered that the battery had swollen. I immediately removed the battery as fast as I could.
Friends suggested that given its been a year that I ask if its possible to get compensation for the battery given that its been a year and 3 months that I could be within warrantee. I have immediately bought a new battery for the meantime.
For context, My usage of the FW16 is to use it like a desktop while at home and dock it, plugging in all my monitors and my 180W charger. I would unplug it when needed for trips but mostly spends its time plugged in and off or on by accident leaving a project open.
If it’s plugged in most of the time, I strongly recommend you limit the battery charge level to 80% or ideally 60% from the BIOS and only change it back to 100% when you need more battery life for being on trips and such.
I’m unsure if there is a way to just use AC power while plugged in, as my previous computer a Lenovo Legion 5 Pro had the option to use AC only once at a certain percentage.
But I’m sure I’ll find the instructions elsewhrere to change the bios for the lower percentage. thanks for the suggestion and I’ll take better care of this one ^^;
