Swollen Battery <1yr in, How to address?
I have my Framework Laptop 13. For a few months now, I’ve been noticing the touchpad getting increasingly difficult to use - slowly, over time. I eventually happened to contact support about a different issue on 9/2 and mentioned it to them. They sent a guide to adjust the touchpad. I didn’t bother with it for a couple of weeks because I was quite busy, and mostly have the laptop docked anyhow.
Then I noticed the front halves were separating and figured, time to figure out what’s going on.
Turns out the battery is swollen. Yikes. Wish they would have mentioned that possibility to me initially, but so it goes.
I started noticing the touchpad issue when the laptop was about 10-11 months old. (The real issue being a battery issue). However, I didn’t contact them about it until 3 days after the expiration of my warranty. They have denied my warranty claim.
So I have some questions…
  1. What can I do to prevent this from happening again?
I’ve seen this happen to laptops occasionally, but generally when they are 4+ years old. I’ve never seen it happen at <1yr.
I do tend to leave my laptop plugged in (to a USB-C charging dock) a lot. But then that has been the case with every laptop I’ve had for years and years. I don’t want to have to replace the battery every 9 months.
I do sometimes need all-day battery life from it so I’ve been hesitant to drop down the max charge level, on the grouns that I’ve never had to do it on any other laptop and a 4-yr battery life is acceptable to me. Is there something different/worse about the Framework battery or charge controller that is impacthing things here, or am I just unlucky?
  1. The problem began within the warranty period, and even documented as such before it was known to be a battery issue, but they still denied it.
This is a Framework 13, 13th gen Intel, with 61Wh battery.
I’ve been very pleased with the laptop, and with Framework’s approach in general, and have complimented Framework quite a bit to friends and on social media.
However, this situation leaves me rather concerned; that it’s a safety issue, that no mention was made that a sticky touchpad could be indicative of a battery failure, and that even though it failed within the warranty period, the claim is denied for having been submitted 3 days after the warranty period.
I think you just got unlucky with your particular battery. In my time here, I don’t recall many reports of similar happening.
If you leave your laptop plugged in “a lot” I would suggest lowering the charge level, at least a little.
It’s certainly not ideal. Either having to remember to disable the limit before you need every drop of battery, or not and just having a little less. But being held at 100% charge is hard on li-ion batteries.
You do take a trade off whatever you do. Either ignore the issue and have accelerated wear (which reduces capacity) and increase risk of early failure if unlucky, or reduce charge limit, if your use sees it held at 100% for hours on end, day after day.
I don’t think that’s something that customer service from any company normally does. Listing every possible reason for an issue. Better to troubleshoot with the customer and find the actual issue.
Thanks. I will definitely set the max charge down in the BIOS. I’m not sure if I was just unlucky or if there is a more systemic reason I had the issue, but it can’t hurt (except when I’m traveling).
Framework support later responded with a satisfactory resolution, which I appreciate! So I consider that part of it resolved.
I have to ask, is there a particular reason you use 78%? Rather than 75 or 80, I mean.
Of course 75 or 80 would just be due a desire for easy fractions. But I must admit I do fall into that. I use 75% charge start threshold & 80 end threshold.
I do 72%…just because I like multiples of 12 (…and 1,2,3,4,6).
Interesting… Do you find the Framework can actually charge beneficially from a USB-A port? I don’t think I’ve seen it do so myself. Those are pretty current-limited, aren’t they?
I would have thought a swollen battery 1 year and 3 days after receiving a new computer would be a a significant issue.
Agree that you should not have to adjust charge thresholds to ensure a battery doesn’t swell up or remains safe.
As if on cue! I got my 61Wh battery a little over a year ago and it swelled yesterday. Is yours 61 or 55?
damn this went from 1 reported case to 3 reported cases of swolen 61wh batteries within a couple days
This comment thread is almost, but perhaps not quite to the level of victim blaming.
I thought somewhat about battery management after I had my laptop for a little while and I came to the conclusion that being able to limit charge is a nice feature and many people will appreciate it, but ultimately I would prefer my laptop to be at 100% charge on the chance that at some point I will need it and I won’t have prior warning of when that might be.
Indeed, this has happened at work when I’ve taken my laptop to a meeting room and that meeting has overrun long enough that I’m into the second meeting with no break.
Keeping your battery at 100% and your laptop powered / charging for 99.9% of its time is not something that should be a concern when we are discussing battery failure. It’s absolutely good advice to not do this if you want to “take it easy” on your battery because you want the battery to have a longer overall useful working life.
The reason I decided 100% / charging 99.9% of the time is fine for me is because it’s a Framework laptop. The battery is easily and cheaply replaceable. There are obvious environmental concerns, but I’m comfortable with my choice.
EDIT: What I’m inexpertly trying to say here is “let’s not scare OP by suggesting that 100% charging is going to expose them to the risk of catastrophic battery failure”, because these batteries are designed to cope with this.
It’s not meant as blaming.
He asked what he could do to prevent it in the future.
While nothing can guarantee it won’t happen, a certain number of batteries are always going to have an issue, not holding the battery at 100% day after day can reduce the risk. It’s a fact of life of current li-ion technology that you must choose, increased stress / wear (leading to reduction of capacity) or limit stress by limiting time held at 100%.
Luckily, Framework makes batteries as easy as possible to replace & without price gouging. So whatever one chooses, it’s fine.
While puffed up cells are a problem, and brings concern, it’s not a catastrophic battery failure. Packs can be surprisingly resilient. I’ve had cell phones that break themselves open from puffed up cells. Severely bending the circuit board and breaking the case in multiple places. Yet the cells resisted puncture.
What’s the third case?
That’s me, this post is two, what’s 3
Then I guess I counted you twice XD
Two in two days is not quite as bad, still not great.
Battery may still work fine but if it doesn’t fit in the laptop anymore that isn’t worth much.
Can we please stop treating a bloated battery like it’s nbd? As someone who’s punctured a battery in my living room (bent a phone battery during replacement), I think it’s a little more serious than that. They’re fire hazards to everything around, and burn hazards to your hands which are resting on top of it. Not to mention strongly poisonous. I have not charged my laptop above 60% (I’ve only charged it at all because I need it for school), and I have the front two input cover screws unscrewed to alleviate all pressure.
I agree with @Be_Far, bloated battery ( also called “spicy pillow”) is not something normal and is a fault of the battery, either by user fault or a manufacture defect.
Remember Galaxy Note 7… battery with defects with no room to “bloat”
For the function of the battery it mostly isn’t (as long as it doesn’t get out of hand but in your pictures the adhesive was still holding it mostly down so there isn’t all that much pressure), for functioning in a device it is because it physically won’t fit and and could get punctured by internal geometry.
The puffing is kind of a downside of pouch cells, cylindrical and prismatics have a venting valve so you don’t notice when they vent but with pouches even the slightest gas production is noticeable. On the other hand it’s an incentive for the manufacturers to make the cells more perfect XD
Non puffed batteries are just as bad if not worse when you puncture them, mechanical damage is a different issue. The state of charge also makes a huge difference about how energetic the event will be if you puncture them, if they are fully discharged to close to 0v like a laptop bms tends to do when it goes int’ safety shutdown they are pretty close to inert.
This may just be pure bad luck or a bad sample, I bought 5 loose pouch cells for a project once (that I of course never actually did as usual) and left them just sitting around, years later one of them was puffed the others were fine, all still at pretty much the same voltage and no charge cycles. That’s just one anecdote on that, the puffing is imo likely not your fault.
I think he means carging from a usb-a source, so 5v. The intel frameworks can do that, the amds physically can too but refuse to due to a ec bug, you can trick it into doing it though.
Kinda, it should work but is broken on the amd frameworks, works fine on the intel ones and would work fine on amd if the ec code for that gets fixed.
But that’s pretty off topic here
