Framework 16 battery cycle life early imminent failure (<200 cycles) barely 80% capacity
I looked for relevant tags but couldn’t even find a [battery] tag. Since I had to pick something I picked some random ones.
  • Which OS (Operating System)?
    Fedora Linux
  • Original Framework 16 batch 2
I realize my battery is well past the one year warrant at ~2.5 years old but I only have roughly 82% capacity left and less than 200 cycles on it. That’s a “recovered” value after it reported 57% capacity left a couple weeks ago. Any chance for a replacement or discount as that’s a quite disappointing cycle life.
sudo ectool battery
Battery 0 info:
OEM name: NVT
Model number: FRANDBAT01
Chemistry : LION
Serial number: 01A3
Design capacity: 5491 mAh
Last full charge: 4508 mAh
Design output voltage 15480 mV
Cycle count 194
Present voltage 17566 mV
Present current 0 mA
Remaining capacity 4508 mAh
Desired voltage 0 mV
Desired current 0 mA
Flags 0x87 AC_PRESENT BATT_PRESENT DISCHARGING
was it plugged in at 100% for long periods of time?
My 2 year battery also has sub 200 cycles, and it dropped some 13%. which I already consider high, since the rating is for them to do 80%+ at 1,000 cycles .. or so they claim
I believe I keep the “stop charging at or above” 85% setting for the longest time, but recently I dropped that to 80%. that 5% doesnt really change anything about it.
All Li-Ion laptop batteries experience calendar aging in addition to cycle aging. The aging is worse for batteries stored at a high charge level over long periods of time.
This is just the chemical breakdown in the battery itself. Nothing can be done to stop it but it can be slowed down.
Keeping batteries at a lower charge level puts less stress on the chemistry internally when not in use. Long term storage of these batteries will age better at 60% than at 80 to 100%. For long term use in a laptop if it lives it’s life primarily on a desk in a conditioned environment leaving it at 60-70% is probably going to do it more favors over time.
It is a consumable part though, and really simple to swap out for a replacement.
@Xavier_Jiang I’ve had it limited to 90% for at least half this time, probably most of it.
@pkunk I know calendar aging is a thing but my car is still holding 88% of it’s original capacity after almost 10 years and about 540 cycles. The laptop battery about to drop under 80% after 2.5 years and less than 200 cycles is incredibly disappointing in comparison.
The comparison to your car is interesting, but laptop packs and EV packs aren’t really managed the same way. EV battery management keeps cells in a tighter window and often has active thermal control, while a thin laptop pack runs warmer and sits at whatever charge level you leave it. That said, under 80% at fewer than 200 cycles with a 90% cap for much of the time does sound like more than calendar aging alone would explain. If it’s still under warranty, documenting the capacity readings might be worth doing before it drops further.
As someone with a first gen FW 16 for over a year (batch # in the teens, but I can’t remember which. I got mine in February '25), I have seen the battery report weird health numbers. I had issues when I installed a flatpak tool but I had issues even before that. The issue stems from the “fuel gauge” or the actual battery meter getting confused and not knowing what the real battery life it. Whenever that issue happens to me it is usually when I sometimes do something high wattage when on low battery. I now use a tool called Framework Tool both GUI and CLI for different tasks. One of the better tools to see some extra stats about the battery is
sudo framework_tool --smartbatterysudo framework_tool --smartbattery
Which gives:
Device Name:   FRANDBAT01
Manuf Name:    NVT
Serial Num:    0091
Manuf Date:    2024-09-28
Chemistry:     LION
FW Version:    Device=0x0045 FW=09.03 Build=0x4900
Mode:          0x6001
Temperature:   38.1C
Voltage:       16.482V
Cell 1:      4.123V
Cell 2:      4.127V
Cell 3:      4.120V
Cell 4:      4.112V
Current:       3.804A (avg 3.804A)
Charge:        22% (1048 / 4806 mAh)
Design:        5491mAh @ 15.480V
Charging:      3.843A @ 17.600V
Bat Status:    0x0080 [INIT (Initialization)]
Cycle Count:   553
=== Battery Health Analysis ===
Status: HEALTHY
No issues detected. Battery is operating normally.
Summary:
Cycle count: 553
Capacity: 4806 / 5491 mAh (88%)
Current cell balance: 15mV spread
[sudo] password for ryker:
Enter unseal key in hex (e.g. 04143672), or press enter to skip:
Manuf Name:    NVT
Serial Num:    0091
Chemistry:     LION
Mode:          0x6001
Temperature:   38.1C
Voltage:       16.482V
Cell 1:      4.123V
Cell 2:      4.127V
Cell 3:      4.120V
Cell 4:      4.112V
Cycle Count:   553
Status: HEALTHY
Summary:
Cycle count: 553
Also, the GUI shows about 88% battery health at 553 cycles showing my battery is aging very healthily, but sometimes it drops sometimes below 50% in which I leave it plugged in overnight. Sometimes I do a battery disconnect in BIOS and then it resolves the issue. Maybe keeping it plugged in will work out for you. Hope this helps!
Today ectool battery shows it as having 90% capacity?? What the heck.
sudo ectool battery
Battery 0 info:
OEM name: NVT
Chemistry : LION
Serial number: 01A3
Last full charge: 4969 mAh
Cycle count 194
Present voltage 17119 mV
Remaining capacity 4503 mAh
Desired voltage 17600 mV
Desired current 3843 mA
Flags 0x83 AC_PRESENT BATT_PRESENT
framework tool gives the same numbers, at least they match
Manuf Name: NVT
Serial Num: 01A3
Manuf Date: 2023-11-24
Chemistry: LION
Mode: 0x6001
Temperature: 30.1C
Voltage: 17.117V
Cell 1: 4.279V
Cell 2: 4.279V
Cell 3: 4.279V
Cell 4: 4.279V
Current: 0.000A (avg 0.000A)
Charge: 91% (4503 / 4969 mAh)
Bat Status: 0x00C0 [DSG (Discharging), INIT (Initialization)]
Cycle Count: 195
Status: HEALTHY
Summary:
Cycle count: 195
Capacity: 4969 / 5491 mAh (90%)
Current cell balance: 0mV spread
Still not sure I trust that the battery is actually at 90% original capacity but with it reporting that high I don’t really have a case for excessive wear suddenly.
Exactly what kept happening to me. I never ended up getting a precise answer. Even from support. All I know for sure that if I keep it plugged in every night it gets better.
I found a topic with more information that should help us
