Hello all,
Today, I happened to check on the battery health of my Framework Laptop 16, and noticed that it was only 87% (i.e. last full charge was 87% of reported designed capacity) according to KDE info centre. Although I expected some degradation of the battery, I did not expect this much after only 145 cycles (the Framework Marketplace listing for the battery states that “Battery typically retains 80% capacity after 1,000 cycles of use.” so I am somewhat concerned about the health of my own battery)
I use the laptop as my primary device, and my use results in some conditions that are less-than-optimal for the battery (deep discharges of the battery, charging to full and leaving the system plugged in for extended periods, semi-frequent high load on the battery due to accidentally knocking my charger loose while gaming on the dgpu, as well as very occasionally finding my system overheated due to it powering on in my bag during my commute, and one time where the cardboard box I rested it on while running VR games deforming under it and obstructing the lower fan intakes). Additionally, there was a period of 3 weeks which started 3 weeks after I got the system (and therefore ended 6 weeks after I got the system) where I did not use it or charge it due to failure of the dgpu leaving the system unbootable while waiting for a replacement dgpu.
I run the system as a dual-boot, with Windows 11 on a M.2 2230 SSD and Fedora 40 (specifically the KDE spin, recently upgraded from 39) on a M.2 2280 SSD. Fedora is my primary operating system, with Windows 11 being reserved for a few workloads that I was unable to get working on Linux in a reasonable amount of time. Although I use the KDE spin, I use swaywm instead of KDE itself (I use the KDE spin because I prefer the KDE applications to their equivalents).
Finally, when I first got the system (I was in batch 6, so it would have been early April iirc), I noticed that the battery charged to more than its designed capacity (although I cannot remember exactly how much more, it was either ~107% or ~115% charge according to i3status). I changed i3status to report charge level as a percentage of the last full charge, since having a charge level greater than 100% reported wasnt my preferred behaviour.
upower -i /org/freedesktop/UPower/devices/battery_BAT1 outputs the following:
native-path: BAT1
vendor: NVT
model: FRANDBA
serial: 041F
power supply: yes
updated: Sat 12 Oct 2024 17:24:24 BST (19 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: fully-charged
warning-level: none
energy: 73.6538 Wh
energy-empty: 0 Wh
energy-full: 73.6848 Wh
energy-full-design: 85.0007 Wh
energy-rate: 0 W
voltage: 17.48 V
charge-cycles: 145
percentage: 99%
capacity: 86.6873%
technology: lithium-ion
icon-name: 'battery-full-charged-symbolic'
My question now is whether my battery is degrading significantly faster than expected due to a defect of the battery (or another piece of the system hardware) or if it is just due to my very poor battery hygiene (now that I think about it, I really have put the battery through a lot).
If it happens to be the former should I contact Framework support?
If it happens to be the latter, how could I better manage my battery health? (for starters, I am going to check to see if there is a maximum charge limit option in the firmware settings right now).
