Hello all,
I just got my Framework 16 with the 7840HS, and after the excitement wore off I ran a Prime95 small FFT torture test (as one does). CPU package power as reported by HWiNFO briefly spikes, then drops to 36 W, then gradually lowers to ~30 W while I reach a core temperature of ~70 C. I think the 36 W limit corresponds to 100% “CPU PPT SLOW Limit”, and the ~30 W limit is 100% “APU STAPM Limit”.
I would be happy, but I was promised 45+ W… Has anyone else seen this behavior? How do I get moar?
More details:
Framework 16 7840HS, no dGPU
100W USB C power adapter plugged in to back left port
Windows 11 Home 23H2, BIOS_3.03, driver_bundle_W11__2024_04_02
Settings>System>Power & Battery>Power Mode is set to “Best Performance”
The bottom of the laptop is in fact so hot it’s very uncomfortable to touch; I’d actually leave the limit same or even lower if I were using it in my lap. However I think it’s strange that other people seem to be reporting much higher power draws and temperatures, and Framework themselves advertise the cooling solution as being able to handle 45 W. Have I overlooked something/is there something else I need to adjust…
I see this behavior on my 65w adapter and my 100w thunderbolt dock as well. If I attach the 180w adapter the power limit goes up to 50w (and thermal throttles at 35w lol) I think it might just cap at 30w for anything other than the stock charger.
Thanks for this comment. This helped me realize that not only do you need the Framework 180W adapter, you also need the Framework 180W USB-C power cord.
I lost my Framework USB-C power cord during travel somewhere, and realized today my CPU Package Power per hwInfo is limited to 30W max. Changed out the USB-C cord I was using from my smartphone to a 3rd-party one specifically rated for 240W USB-C PD EPR, and now it’s drawing 37W.
Still out of spec as it should be drawing 50W, but now I can see the CPU cores are peaking at 100C and I need yet another thermal replacement. (Support “fixed” my laptop’s liquid metal cooling after keeping it at their service center for 3 months. Then a month later Framework announced that the liquid metal doesn’t really work for anyone, and anyone who notices their benchmarks aren’t showing proper performance should contact support for a thermal pad replacement kit.)
This behavior doesnt make sense, why should the laptop perform worse on AC than on battery? When I unplug my laptop from a power source less than 100w, the power limit goes UP to 45w.
I thought the original EC firmware didnt do this, I noticed it after I updated my BIOS. Framework needs to fix this behavior to give consistent performance. The battery is able to assist on a 15w power source, so why not a 65w power source?
