Hi
I’ve seen that the Framework Desktop (128 GB) is currently not available.
Do you already know when it will be available again?
Regards
Hemeden
Hi
Regards
Hemeden
Guessing that this might be the reason it’s out of stock?
OK, thanks for update ![]()
Bad for me missing the last batch
What country are you in? It is still available in the UK, with yet another hike compared to when I last checked! ![]()
That’s odd, when I looked yesterday the 128GB version was showing as out of stock in the UK. Must be changing rapidly.
Yeah now it’s back.
Good for us ![]()
I would expect the stock levels to vary by locale. For example, refurb Desktops are available in the US, but not the UK. I should think this is the same thing - and the numbers will be going up and down, so they likely will be published and unpublished automatically.
