Framework Desktop as video editing and motion graphics machine
I was going to buy a MAC again after ten years of using windows thanks to the M4 chip… When i saw the presentation of fremework desktop I couldn’t do it… so I pre-ordered it instead. Is it a powerful enough for After effects, Premiere and Blender? I suppose with 120w its going to score better than the Strix Halo laptops (70-80w).
Well…
it’s not going to beat an R7 9950X with a 7900XTX or 4090 in processing power…
but the benchmarks for the Radeon 8060S is about on par with a RTX 2060 Super and about 20% slower than a Radeon 6700 XT.
with a 50% higher TDP compared to the laptop solutions implementing the chips i’d expect a roughly proportional increase in performance.
So, yes it’ll do those things just fine compared to a laptop doing the same tasks, but a dedicated full workstation could still beat it, which is to be expected really…
well, it depends. What mac are you comparing against?
and what would your budget be (so I can compare to a PC)
No I get it I have a workstation at work it’s for experimenting and learning a home… and for my daughter to do some gaming I think it will do fine.
Thanks for replying.
I’m getting the 395+ with 128gram will it be slower than Mac mini M4 pro with 64gram?
Impossible to say for sure. the Desktop’s not out yet and benchmarks between Windows/Linux PCs and Mac is very much “It depends”
some apps behave significantly better on Windows than Mac, and the reverse is true on a case by case basis.
That being said…
the geekbench scores for the Mac Mini M4 show 3826 Single-Core / 22340 Multi-Core / 69667 OpenCL GPU [1]
and i was able to find this laptop that has posted a geekbench score with the same chip that the Framework will have…
The ASUS ROG Flow Z13 posts geekbench scores of 2960 Single-Core / 21488 Multi-Core / No listed GPU score [2]
Given the TDP differences between the laptop and the desktop the benchmarks imply a “within spitting distance” placement when comparing the desktop and the Mac.
[1] https://browser.geekbench.com/macs/mac-mini-2024-14c-cpu
[2] ASUSTeK COMPUTER INC. ROG Flow Z13 GZ302EA_GZ302EA - Geekbench
That’s what I thought, Stix halo running on desktop and 128gram it will be very close. :+1:
in terms of raw performance, yes.
maybe not in terms of media encoders, but the sheer amount of RAM on the framework should make it a much better choice for this.
Real world applications it looks very strong even at 70w especially with RAM allocation…
