Framework Desktop Fedora 44 kde, Randomly waking up
  • Famework Desktop w. Ryzen AI Max 395+
  • OS: Fedora 44 Workstation KDE, Clean Install
  • latest bios 3.05
I’ve been losing my mind trying to get my Framework desktop to only wake up:
  • if I use my keyboard or mouse (via a logitech unifying receiver, so not bluetooth but USB)
  • if I send it a WWOL (wake on wireless lan) packet from another machine on the same wifi network
  • there is nothing else plugged in except the Logitech Unifying Receiver
I’ve enabled Wake on Lan in BIOS, and Wireless Wake on Lan in the OS
Now I randomly get my PC woken up from sleep, it wakes up is the LED suddenly and stays ON and I hear the fans coming on.
The weird part is the video out is not working, although fans are working.
To fully enable video out I have to try to wake it up again using mouse/kb.
There’s no possibility that the mouse and kb have triggered it since I turn them both off right after sleep and I checked and the unifying receiver is only paired with these 2 devices that I turn off.
I tried everything, I created some custom scripts and wake override scripts with chatgpt
for dev in GPP0 GPP1 GPP3 GPP5 GPP7 NHI0 NHI1; do
ifgrep -q "^$dev.*enabled"/proc/acpi/wakeup; then
echo "$dev"> /proc/acpi/wakeup
fi
done
If it helps here’s the output from cat /proc/acpi/wakeup
Device S-state Status Sysfs node
GPP0 S4 *enabled pci:0000:00:01.1
SWUS S4 *disabled
GPP1 S4 *enabled pci:0000:00:01.2
SWUS S4 *disabled
GPP3 S4 *enabled pci:0000:00:02.1
GPP5 S4 *enabled pci:0000:00:02.3
GPP7 S4 *enabled pci:0000:00:02.5
GPP9 S4 *disabled
XHC1 S4 *enabled pci:0000:c2:00.4
XHC0 S4 *enabled pci:0000:c4:00.0
XHC3 S4 *enabled pci:0000:c4:00.3
XHC4 S4 *enabled pci:0000:c4:00.4
NHI0 S4 *enabled pci:0000:c4:00.5
NHI1 S4 *enabled pci:0000:c4:00.6
This is what journalctl tells me
f44 kernel: PM: suspend devices took 0.165 seconds
f44 kernel: ACPI: EC: interrupt blocked
f44 kernel: ACPI: EC: interrupt unblocked
f44 kernel: amdgpu 0000:c2:00.0: [drm] PCIE GART of 512M enabled (table at 0x00>
f44 kernel: amdgpu 0000:c2:00.0: SMU is resuming...
f44 kernel: amdgpu 0000:c2:00.0: SMU is resumed successfully!
f44 kernel: nvme nvme0: 8/0/0 default/read/poll queues
f44 kernel: amdgpu 0000:c2:00.0: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.0.0 uses VM inv eng 1 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.1.0 uses VM inv eng 4 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.2.0 uses VM inv eng 6 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.3.0 uses VM inv eng 7 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.0.1 uses VM inv eng 8 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.1.1 uses VM inv eng 9 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.2.1 uses VM inv eng 10 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring comp_1.3.1 uses VM inv eng 11 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring sdma0 uses VM inv eng 12 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring vcn_unified_0 uses VM inv eng 0 on hub 8
f44 kernel: amdgpu 0000:c2:00.0: ring vcn_unified_1 uses VM inv eng 1 on hub 8
f44 kernel: amdgpu 0000:c2:00.0: ring jpeg_dec_0 uses VM inv eng 4 on hub 8
f44 kernel: amdgpu 0000:c2:00.0: ring jpeg_dec_1 uses VM inv eng 6 on hub 8
f44 kernel: amdgpu 0000:c2:00.0: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
f44 kernel: amdgpu 0000:c2:00.0: ring vpe uses VM inv eng 7 on hub 8
f44 kernel: PM: resume devices took 0.303 seconds
f44 kernel: OOM killer enabled.
f44 kernel: Restarting tasks: Starting
f44 kernel: Restarting tasks: Done
f44 kernel: efivarfs: resyncing variable state
f44 kernel: efivarfs: finished resyncing variable state
f44 kernel: random: crng reseeded on system resumption
f44 kernel: PM: suspend exit
f44 systemd-sleep[3264]: System returned from sleep operation 'suspend'.
f44 bluetoothd[1100]: Controller resume with wake event 0x0
f44 kwin_wayland[1893]: The main thread was hanging temporarily!
f44 systemd[1]: user.slice: Unit now thawed.
f44 systemd[1]: user-1000.slice: Unit now thawed.
f44 systemd[1]: session-1.scope: Unit now thawed.
f44 systemd-sleep[3264]: Successfully thawed unit 'user.slice'.
f44 systemd[1]: user@1000.service: Unit now thawed.
f44 systemd[1]: systemd-suspend.service: Deactivated successfully.
f44 systemd[1]: Finished systemd-suspend.service - System Suspend.
f44 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=sys>
f44 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=syst>
f44 systemd[1]: Stopped target sleep.target - Sleep.
f44 systemd[1]: Reached target suspend.target - Suspend.
f44 systemd-logind[1155]: Operation 'suspend' finished.
f44 systemd[1]: Stopped target suspend.target - Suspend.
f44 systemd-resolved[869]: Closing all remaining TCP connections.
f44 systemd-resolved[869]: Resetting learnt feature levels on all servers.
f44 ModemManager[1230]: [sleep-monitor-systemd] system is resuming
f44 NetworkManager[1104]: [1785064459.7629] manager: sleep: wake reques>
f44 NetworkManager[1104]: [1785064459.7630] device (wlp192s0): state ch>
f44 NetworkManager[1104]: [1785064459.7632] dhcp4 (wlp192s0): canceled >
f44 NetworkManager[1104]: [1785064459.7632] dhcp4 (wlp192s0): activatio>
f44 NetworkManager[1104]: [1785064459.7632] dhcp4 (wlp192s0): state cha>
f44 NetworkManager[1104]: [1785064459.7633] dhcp6 (wlp192s0): canceled >
f44 NetworkManager[1104]: [1785064459.7633] dhcp6 (wlp192s0): activatio>
f44 NetworkManager[1104]: [1785064459.7633] dhcp6 (wlp192s0): state cha>
Note that after I noticed the fans spinning up and LED staying on, I then gave it KB and mouse input to wake it for video out and try to troubleshoot.
Don’t know if it’ll do it from sleep, but my Fedora 44 will wake up from idle/screen blank when the Software app determines there are new updates to install, to generate an alert to that effect.
In my case it has nothing to do with that, once I enable Wake from Wifi, it begins erratically waking up.
Before that, not an issue.
Based on what others have reported, the issue appears to be it wakes up from traffic on the home network, and not from magic packets which should be what it wakes it up.
