Framework Desktop Keeps Disconnecting Framework USB-C Storage Device
I’m having an issue with the 1TB Framework Storage device when using either of the front USB-C bays. I’m trying to rsync some data over to it and keep getting stuff like this:
[1262129.817003] usb 4-2.1: new SuperSpeed Plus Gen 2x1 USB device number 5 using xhci_hcd
[1262129.828654] usb 4-2.1: New USB device found, idVendor=32ac, idProduct=0005, bcdDevice= 1.10
[1262129.828673] usb 4-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1262129.828677] usb 4-2.1: Product: 1TB Expansion Card
[1262129.828680] usb 4-2.1: Manufacturer: Framework
[1262129.828681] usb 4-2.1: SerialNumber: 071C48FA31201277
[1262129.831351] scsi host0: uas
[1262131.094452] scsi 0:0:0:0: Direct-Access     FRMW     1TB Card         PMAP PQ: 0 ANSI: 6
[1262131.146396] sd 0:0:0:0: Attached scsi generic sg0 type 0
[1262131.149783] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[1262131.152296] sd 0:0:0:0: [sda] Write Protect is off
[1262131.152302] sd 0:0:0:0: [sda] Mode Sense: 5f 00 00 08
[1262131.158059] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[1262131.185231] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[1262131.185243] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
[1262131.234943] sd 0:0:0:0: [sda] Attached SCSI disk
[1262196.308522] XFS (sda): Mounting V5 Filesystem 7b1ad154-7a27-434b-8213-4cdcff7fb5dd
[1262196.379597] XFS (sda): Starting recovery (logdev: internal)
[1262196.421469] XFS (sda): Ending recovery (logdev: internal)
[1262216.597053] sd 0:0:0:0: [sda] tag#22 data cmplt err -71 uas-tag 12 inflight: CMD
[1262216.597068] sd 0:0:0:0: [sda] tag#22 CDB: Write(10) 2a 00 3b 88 dc e8 00 03 00 00
[1262221.871657] scsi host0: uas_pre_reset: timed out
[1262221.973487] sd 0:0:0:0: [sda] tag#16 uas_zap_pending 0 uas-tag 1 inflight: CMD
[1262221.973492] sd 0:0:0:0: [sda] tag#16 CDB: Write(10) 2a 00 3b 88 e2 e8 00 04 00 00
[1262221.973495] sd 0:0:0:0: [sda] tag#25 uas_zap_pending 0 uas-tag 2 inflight: CMD
[1262221.973496] sd 0:0:0:0: [sda] tag#25 CDB: Write(10) 2a 00 3b 88 e6 e8 00 04 00 00
[1262221.973497] sd 0:0:0:0: [sda] tag#26 uas_zap_pending 0 uas-tag 3 inflight: CMD
[1262221.973498] sd 0:0:0:0: [sda] tag#26 CDB: Write(10) 2a 00 3b 88 ea e8 00 04 00 00
[1262221.973499] sd 0:0:0:0: [sda] tag#27 uas_zap_pending 0 uas-tag 4 inflight: CMD
[1262221.973500] sd 0:0:0:0: [sda] tag#27 CDB: Write(10) 2a 00 3b 88 ee e8 00 04 00 00
[1262221.973501] sd 0:0:0:0: [sda] tag#28 uas_zap_pending 0 uas-tag 5 inflight: CMD
[1262221.973501] sd 0:0:0:0: [sda] tag#28 CDB: Write(10) 2a 00 3b 88 f2 e8 00 04 00 00
[1262221.973503] sd 0:0:0:0: [sda] tag#29 uas_zap_pending 0 uas-tag 6 inflight: CMD
[1262221.973503] sd 0:0:0:0: [sda] tag#29 CDB: Write(10) 2a 00 3b 88 f6 e8 00 04 00 00
[1262221.973504] sd 0:0:0:0: [sda] tag#22 uas_zap_pending 0 uas-tag 12 inflight: CMD
[1262221.973505] sd 0:0:0:0: [sda] tag#22 CDB: Write(10) 2a 00 3b 88 dc e8 00 03 00 00
[1262221.973506] sd 0:0:0:0: [sda] tag#23 uas_zap_pending 0 uas-tag 13 inflight: CMD
[1262221.973507] sd 0:0:0:0: [sda] tag#23 CDB: Write(10) 2a 00 3b 88 df e8 00 03 00 00
[1262221.973508] sd 0:0:0:0: [sda] tag#24 uas_zap_pending 0 uas-tag 14 inflight: CMD
[1262221.973509] sd 0:0:0:0: [sda] tag#24 CDB: Write(10) 2a 00 38 c1 e1 70 00 00 08 00
[1262221.973510] sd 0:0:0:0: [sda] tag#0 uas_zap_pending 0 uas-tag 15 inflight: CMD
[1262221.973511] sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 3b 88 fa e8 00 04 00 00
[1262221.973512] sd 0:0:0:0: [sda] tag#1 uas_zap_pending 0 uas-tag 16 inflight: CMD
[1262221.973513] sd 0:0:0:0: [sda] tag#1 CDB: Write(10) 2a 00 3b 88 fe e8 00 04 00 00
[1262221.973514] sd 0:0:0:0: [sda] tag#2 uas_zap_pending 0 uas-tag 17 inflight: CMD
[1262221.973514] sd 0:0:0:0: [sda] tag#2 CDB: Write(10) 2a 00 3b 89 02 e8 00 04 00 00
[1262221.973515] sd 0:0:0:0: [sda] tag#3 uas_zap_pending 0 uas-tag 18 inflight: CMD
[1262221.973516] sd 0:0:0:0: [sda] tag#3 CDB: Write(10) 2a 00 3b 89 06 e8 00 04 00 00
[1262221.973517] sd 0:0:0:0: [sda] tag#4 uas_zap_pending 0 uas-tag 19 inflight: CMD
[1262221.973517] sd 0:0:0:0: [sda] tag#4 CDB: Write(10) 2a 00 3b 89 0a e8 00 04 00 00
[1262221.973518] sd 0:0:0:0: [sda] tag#5 uas_zap_pending 0 uas-tag 20 inflight: CMD
[1262221.973519] sd 0:0:0:0: [sda] tag#5 CDB: Write(10) 2a 00 3b 89 0e e8 00 04 00 00
[1262221.973520] sd 0:0:0:0: [sda] tag#6 uas_zap_pending 0 uas-tag 21 inflight: CMD
[1262221.973520] sd 0:0:0:0: [sda] tag#6 CDB: Write(10) 2a 00 3b 89 12 e8 00 04 00 00
[1262221.973521] sd 0:0:0:0: [sda] tag#7 uas_zap_pending 0 uas-tag 22 inflight: CMD
[1262221.973522] sd 0:0:0:0: [sda] tag#7 CDB: Write(10) 2a 00 3b 89 16 e8 00 04 00 00
[1262221.973775] scsi_io_completion_action: 11 callbacks suppressed
[1262221.973821] sd 0:0:0:0: [sda] tag#16 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.973830] sd 0:0:0:0: [sda] tag#16 CDB: Write(10) 2a 00 3b 88 e2 e8 00 04 00 00
[1262221.973833] blk_print_req_error: 44008 callbacks suppressed
[1262221.973836] I/O error, dev sda, sector 998826728 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.974181] sd 0:0:0:0: [sda] tag#25 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.974186] sd 0:0:0:0: [sda] tag#25 CDB: Write(10) 2a 00 3b 88 e6 e8 00 04 00 00
[1262221.974190] I/O error, dev sda, sector 998827752 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.974481] sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.974484] sd 0:0:0:0: [sda] tag#26 CDB: Write(10) 2a 00 3b 88 ea e8 00 04 00 00
[1262221.974486] I/O error, dev sda, sector 998828776 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.974676] sd 0:0:0:0: [sda] tag#27 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.974678] sd 0:0:0:0: [sda] tag#27 CDB: Write(10) 2a 00 3b 88 ee e8 00 04 00 00
[1262221.974679] I/O error, dev sda, sector 998829800 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.974829] sd 0:0:0:0: [sda] tag#28 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.974831] sd 0:0:0:0: [sda] tag#28 CDB: Write(10) 2a 00 3b 88 f2 e8 00 04 00 00
[1262221.974832] I/O error, dev sda, sector 998830824 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.974977] sd 0:0:0:0: [sda] tag#29 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.974980] sd 0:0:0:0: [sda] tag#29 CDB: Write(10) 2a 00 3b 88 f6 e8 00 04 00 00
[1262221.974981] I/O error, dev sda, sector 998831848 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.975127] sd 0:0:0:0: [sda] tag#22 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.975129] sd 0:0:0:0: [sda] tag#22 CDB: Write(10) 2a 00 3b 88 dc e8 00 03 00 00
[1262221.975130] I/O error, dev sda, sector 998825192 op 0x1:(WRITE) flags 0x104000 phys_seg 96 prio class 2
[1262221.975276] sd 0:0:0:0: [sda] tag#23 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.975278] sd 0:0:0:0: [sda] tag#23 CDB: Write(10) 2a 00 3b 88 df e8 00 03 00 00
[1262221.975280] I/O error, dev sda, sector 998825960 op 0x1:(WRITE) flags 0x100000 phys_seg 96 prio class 2
[1262221.975433] sd 0:0:0:0: [sda] tag#24 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.975436] sd 0:0:0:0: [sda] tag#24 CDB: Write(10) 2a 00 38 c1 e1 70 00 00 08 00
[1262221.975438] I/O error, dev sda, sector 952230256 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 2
[1262221.975584] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK cmd_age=5s
[1262221.975586] sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 3b 88 fa e8 00 04 00 00
[1262221.975587] I/O error, dev sda, sector 998832872 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 2
[1262221.976186] iomap_finish_ioend_buffered: 2116 callbacks suppressed
[1262221.976187] sda: writeback error on inode 1043148479, offset 0, sector 998818024
[1262221.976205] sda: writeback error on inode 1046172544, offset 0, sector 998825960
[1262221.976433] sda: writeback error on inode 1043148478, offset 0, sector 952230256
[1262221.976808] sda: writeback error on inode 1046172545, offset 0, sector 998826728
[1262221.977134] sda: writeback error on inode 1046172545, offset 61079552, sector 998946024
[1262221.977201] sda: writeback error on inode 1046172550, offset 0, sector 999267152
[1262221.977328] sda: writeback error on inode 1046172546, offset 0, sector 998958608
[1262221.977412] sda: writeback error on inode 722589506, offset 0, sector 999284048
[1262221.977422] sda: writeback error on inode 1046172551, offset 0, sector 999292408
[1262221.977474] sda: writeback error on inode 1046172552, offset 0, sector 999298128
[1262222.552677] XFS (sda): log I/O error -19
[1262222.553095] XFS (sda): Filesystem has been shut down due to log error (0x2).
[1262222.553241] XFS (sda): Please unmount the filesystem and rectify the problem(s).
[1262222.553399] XFS (sda): log I/O error -19
[1262222.553537] XFS (sda): log I/O error -19
[1262222.553678] XFS (sda): log I/O error -19
[1262222.553811] XFS (sda): log I/O error -19
[1262222.553946] XFS (sda): log I/O error -19
[1262222.554078] XFS (sda): log I/O error -19
[1262222.554206] XFS (sda): log I/O error -19
[1262223.015100] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[1262223.175874] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[1262223.476950] usb 4-2.1: reset SuperSpeed Plus Gen 2x1 USB device number 5 using xhci_hcd
[1262223.491009] scsi host1: uas
[1262223.503217] scsi 1:0:0:0: Direct-Access     FRMW     1TB Card         PMAP PQ: 0 ANSI: 6
[1262223.537844] sd 1:0:0:0: Attached scsi generic sg0 type 0
[1262223.540428] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[1262223.542571] sd 1:0:0:0: [sdb] Write Protect is off
[1262223.542577] sd 1:0:0:0: [sdb] Mode Sense: 5f 00 00 08
[1262223.546673] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[1262223.571989] sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[1262223.572001] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
[1262223.613256] sd 1:0:0:0: [sdb] Attached SCSI disk
Both bays seem to be doing it. I’m running Ubuntu 24.04 (server) and am trying to rsync ~400GB of data. This seems to happen whether or not I create a partition table or simply use the whole disk for the filesystem (XFS).
I was previously trying to use it with my Framework 13" (with full disk encryption) but I found it flaky. I was hoping that wouldn’t be the case for the Desktop. I find it’s good to ~250GB and then it starts to have issues much more rapidly.
Anyone have any idears?
I was able to finish the rsync by adding --bwlimit 250M. Trying to find a way to limit performance via mount options or some such. Looks like I have to use cgroups for that.
@Tim_Soderstrom You have most likely hit on the USB-C port underpower issue.
Edit: was the problem with the front USB-C ports or the back USB4.0 ones? If it’s the USB4.0 ones, then yes I think it’s the USB-C 15W power profile issue. If the front ports, still possible a power issue but not exactly what I mentioned below.
See details here
And the discussions in this thread around these parts:
I would suggest adding your case in the Github issue and contact support.
I read up on the rear power USB ports yep. I tried it in both the front ports, but not the rears. I’ll read those links over though thanks! Does seem plausible that it could be a power issue though yep.
