Framework Desktop (Ryzen AI Max 385) Heatsink technical drawing
Hi,
I have HDPLEX H3 Fanless PC Chassis
I would like to mill/create my own heatsink that would cover the same area as the heatsink delivered with the product. I want to use HDPlex heatpipes and connect the heatsink with the chassis… Do you know if there is a technical drawing / CAD of the original Framework heatsink?
My worries are that if I would use just the heatsink that goes with HDPlex, it would leave Framework board without cooling of some additional components…
Thanks in advance for any suggestion/help.
Not yet, but I’m actively working on the same thing which is kind of funny
I documented the Motherboard dimensions that I measured in this thread:
and I’m currently in the mock up stage using my 3d printer:
3rd time’s the charm (technically 4th try, I broke one removing the support/shim for the recessed hexagon (that’s where I’m mounting my cooler, which is a waterblock))
Edit: I still need to do a fit with thermal pads and obviously make one out of aluminum
