Which Framework Desktop model are you using? (AMD Ryzen™ AI Max 300 Series)
AMD Ryzen AI Max+ 395 w/ 128GB RAM
Continue to get crashes. With 3.0.4 I would get a GPU freeze-up. Downgrading to 3.0.3 worked for a while until in the middle of a long-ish video conference the system froze and restarted.
[ 2.203806] x86/amd: Previous system reset reason [0x08000800]: an uncorrected caused a data fabric sync flood event
Sniffing around, I see I’m not the only one with this problem.
Absolutely ZERO bios changes have been made at this point. Had some fan issues, bought some headphones. That’s the gist of it. Trying to work. Just work. And this machine seems exceptionally unstable at this point.
Does anyone know if this issue is being investigated for inclusion in 3.0.5? Any advance bios settings that can be done to prevent this from happening. Spending a lot of money on a pretty paper-weight isn’t what I had in mind.
Yeah, I am having problems like this too. For me it restarts once a day or sometimes 3-4 times a day. It becomes unusable a times. I also have an AMD GPU in linux, almalinux.
I appreciate the tip, James, but that thread is for a version of BIOS that does not exist for the laptop AND is a different AMD architecture. So can you help me understand what you believe is the “relevant” portion of that AER issue but cause the thread also covers at least 14 months of feedback.
