I have seen a lot of topics about building custom-built mini PCs using the Framework Strix Halo mainboards.
I am not sure if this has been discussed in the past but I am planning to purchase a FW Desktop mainboard with a Ryzen AI Max 385 for light AI use. I am thinking of running small models like gpt-oss 20 B on it. Would you say that it is possible to run such models at decent speed given that the Strix Halo series has seen a lot of software/driver improvements when it comes to AI?
Then I would like to know if someone has build a PC using the Jonsbo N10 already. Because I am looking into buying that one.
At last, what are your experiences with Framework Desktop mainboards? Have many of you run into problems with curl whine or mainboard failure issues?
Any answer is really appreciated. Thank you in advance.
What kind of AI work are you looking to do? My interest is code generation, and I’ve a thread on that topic here:
Second item:
Various cases, including the Jonsbo, get a mention here:
Final item:
Failure is hard for each person to comment on, because only Framework see numbers to a statistically significant degree. Everyone else sees a handful of failures at worst, which is not enough to comment on. Your main guard against problems is the warranty, which is one, two, or three years long depending on where you live. I’d love to see returns data from Framework, but I assume it is regarded as proprietary information by any system maker.
I assume you’re interested in using a case to permit the addition of a GPU. If so, this thread will be useful:
You may find it useful to know that the PCIe interface is four lanes of data using version 4.0 of the protocol. This may not be a problem if you can fit models entirely in dGPU VRAM, since the additional delay is a one-off cost.
I have a 128gb 395 in a Soeyi U300, this is what it looks like at the moment (really horrible heatsink, waiting on my Framework heatsink, that’s a pleated prefilter at the bottom and the dust filter at the top to catch dust drifting downward while it’s off). Could’ve gone one size smaller on the case length if the idea is to stick to low profile air cooling.
I guess it depends on what you’re running but I would personally slam into the 32gb ceiling pretty fast with my habit of leaving 50 browser tabs open. The 8050 is not that much slower than the 8060. One idea for freeing 1-2gb of RAM is to add some extremely cheap old card like a Quadro P400 to run the desktop video output.
The Max 385 and Max+ 395 have the same memory bandwidth of 256 GB/s, so the inference speed should be about the same (Memory Bandwidth bound). Here’s a single reddit post two years ago about the 7900xtx vs 7900xt, the Memory Bandwidth of the 7900xt is 83.3% of the 7900xtx and the llama.cpp inference speed is about 81.2%, implying correlation.
The Max 385 and Max+ 395 have 32 and 40 compute units, respectively. That means the prompt processing speed for the Max 385 should be about 80% of the Max+ 395. The same reddit post above shows that using 87.5% of the compute units gets 85.2% of the prompt processing speed, again implying correlation.
The same cannot be said of the two Nvidia cards shown, they’re different generations with enough notable changes.
So just mathing it out:
gpt-oss-20b with rocm-7_2_3
AI Max+ 395 (from the kyuz0 benchmarks)
Prompt processing (pp512): 1786.17 t/s
Token generation (tg128): 73.05 t/s
AI Max 385 (calculated)
Prompt processing (pp512): 1428 t/s (80% of AI Max+ 395)
Drop down to 1071 t/s if we expect 60% of the performance, still manageable.
