Hey everyone,
I recently got my Framework 13 and installed a couple of distros on it.
I had the most success with NixOS and thought it would be a good idea to share my simple configuration.nix
It doesn’t use Homemanager or Flakes yet and is merely meant for people that want to quick start their NixOSxFramework journey.
Please remember to follow the short notes I left and register your finger, run the fwupd commands and make sure to change the desktop from Gnome to plasma or whatever u want to use etc.
Github link:
# Edit this configuration file to define what should be installed on
# your system. Help is available in the configuration.nix(5) man page
# and in the NixOS manual (accessible by running ‘nixos-help’).
{ config, pkgs, ... }:
imports =
[ # Include the results of the hardware scan.
./hardware-configuration.nix
# Bootloader.
boot.loader.systemd-boot.enable = true;
boot.loader.efi.canTouchEfiVariables = true;
networking.hostName = "nixos"; # Define your hostname.
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
# Configure network proxy if necessary
This file has been truncated. show original
Cheers
The best part of nixos is being able to see what my system will become before deploying it.
Is the experimental bluetooth required? I dont have my fw yet.
Ah no, I had it in there due to some issues with my new LDAC compatible headphones.
You can leave it out if you don’t need LDAC
From what I found out, it was only required to turn off multipoint pairing within the headphonesa (Edifier 980) app to use LDAC.
Let me remove that line, thanks for the heads up!
Suggestions to change the config:
services.fwupd.extraRemotes = [ "lvfs-testing" ];
Not required, 3.03 AMD bios is no longer beta
import framework 16 profile for drivers
Can then remove:
services.fprintd.enable = true;
services.fprintd.tod.driver = pkgs.libfprint-2-tod1-vfs0090;
as its enabled in the framework 16 7040 profile along with other things.
Will give it a look and come back once done! Thx for notifying, I heard about Framework’s new Team for the Firmware.
Didn’t expect such rapid change!
Update: thx for the heads up added tarball for the repo and works like a charm.
I just realized I am in the framework 13 part of the forum. I gave info on framework 16 stuff. So you might need lvfs-testing still.
Nope, seems to be running fine haha, even smoother than before tbh.
Regards,
