I’m on latest LTS Neon (24.04) on my AMD Framework 16, and no matter what I do I can’t get the AMD dGPU fan to run. I got to run yesterday for 10 seconds after “hacking” the installer for the amdgpu by bypassing checking the OS version, but that caused to many other issues.
I’ve tried just about every fan control solution (LACT, fanctonrol-fw, ectool, etc etc) and the fan just does not turn on.
Output off the sensors command:
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +44.5°C
amdgpu-pci-c500
vddgfx: 877.00 mV
vddnb: 658.00 mV
edge: +41.0°C
PPT: 9.18 W (avg = 8.17 W)
ucsi_source_psy_USBC000:002-isa-0000
Adapter: ISA adapter
in0: 0.00 V (min = +0.00 V, max = +0.00 V)
curr1: 680.00 mA (max = +0.00 A)
mt7921_phy0-pci-0500
temp1: +44.0°C
nvme-pci-0400
Composite: +34.9°C (low = -40.1°C, high = +83.8°C)
(crit = +87.8°C)
Sensor 1: +46.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +34.9°C (low = -273.1°C, high = +65261.8°C)
BAT1-acpi-0
Adapter: ACPI interface
in0: 17.60 V
curr1: 0.00 A
ucsi_source_psy_USBC000:004-isa-0000
in0: 20.00 V (min = +5.00 V, max = +0.40 V)
curr1: 5.00 A (max = +3.56 A)
ucsi_source_psy_USBC000:003-isa-0000
in0: 5.00 V (min = +5.00 V, max = +5.00 V)
curr1: 0.00 A (max = +1.50 A)
amdgpu-pci-0300
vddgfx: 828.00 mV
fan1: 0 RPM (min = 0 RPM, max = 4900 RPM)
edge: +34.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
junction: +42.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
mem: +39.0°C (crit = +105.0°C, hyst = -273.1°C)
(emerg = +110.0°C)
PPT: 37.00 W (cap = 100.00 W)
ucsi_source_psy_USBC000:001-isa-0000
curr1: 0.00 A (max = +0.00 A)
nvme-pci-0600
Composite: +36.9°C (low = -5.2°C, high = +89.8°C)
(crit = +93.8°C)
acpitz-acpi-0
temp1: +40.8°C
temp2: +41.8°C
temp3: +43.8°C
temp4: +43.8°C
Screenshot of LACT:
When I boot into the Windows 11 OS the fan works…but opposite. When AMD software switches to dGPU the fans are essentially at 100% the entire time.
Update:
After installing oem kernel, LACT now shows fan controls. However when I try to set a static fan speed I get the following error message:
ould not set fan control
Caused by:
0: Got error from daemon, end of client boundary
1: Failed to edit GPU config
2: Could not apply settings
3: Failed to set static fan control
4: could not set fan speed
5: io error: Invalid argument (os error 22)
I don’t remember having this issue on the previous 2 LTS releases of Neon or Ubuntu.
Update 2:
The issue was PEBCAK,… I was using my 65W charger. After plugging in the 125W charger, the fans are working now. I still can’t set the speed or curve for it.
