FW 16 180W Power Brick Sleeve
After accidentally tripping over my 180W power brick for my Framework 16 and breaking the USB-C port, I decided to CAD this file to reinforce that connection and prevent unnecessary play in the connection. If you have a Framework 16 with the 180W, I HIGHLY recommend doing this so you don’t have to buy another $140 charger like I did. (FYI, Its printable in any quality, but if you use snug supports like I did on rough the hexagon support will not come out)
Here’s the Thingiverse link
Thank you for this. I have had some close calls with my charger. I will print this to help protect it.
