FW16 - Applications trying to use discrete module crash after update
So, I have a weird issue. After updating the driver bundle from the December bundle (1.2) to the latest one (2.0), games or programs that try to use my graphics module fail to run. On the old ones, every game worked, on the new ones only apps that use the integrated graphics work.
FH6 crashes with a video card crash error
CS2 is stuck at the Valve logo
ETS2 works in theory, but is unusable and laggy.
I tried every possible solution, DDU, the AMD cleanup utility, extracting the amd drivers from the bundle and installing them as driver only, nothing fixes it, unless I uninstall the current ones and go back to the older drivers.
Has anybody experienced this issue and knows how to fix it?
Laptop model: Framework 16 (AI 9 HX 370, 64GB memory) + RX 7700s 2nd gen
Firmware: 03.06
Operating system: Windows 11 (build 26100.8655)
i have noticed similar issues with certain games where the start up seems panfuilly slow or really framey for me it was amd drivers that needed to be updated granted mine was the interagted I and I use a nivida gpu
