Fw16 clear bezel show and tell
Just got some 3d printed parts in and thought I would show them sooner than later if it helps other people. The bezel clips in fine on the top but bows in on the bottom, I ordered some magnets and will try to add them soon. The bezel is a frail thing
The clear bezel comes from Bezel for Framework 16 by Mapou Trautman | Download free STL model | Printables.com. This is printed by Xometry with Polyjet: Translucent, Clear Photopolymer.
track pad piece from https://www.etsy.com/listing/4373742914/framework-16-laptop-single-piece?ref=yr_purchases
An all-transparent look is really cool!
How much does the bezel flex compared to a stock one?
Sick build. I have to get me that touchpad and spacer combo…
it flexes pretty much the same it’s just not as sturdy.
