Not sure if this qualifies as a hardware issue, BIOS bug, or skill issue on my part configuring the computer. Wondering if anyone over here has any ideas and/or has seen the same thing.
I’ve had my FW16 for a fairly short while (so the W11 OS is nearly clean), but I hadn’t had an occasion until today to be listening to music while I plugged in or unplugged the charger. So I never noticed it stutter/lag when I unplugged or plugged in the charger.
edit to add - happens on both bluetooth and speakers
With task manager open, I can see the clock speed drop to as low as 0.53GHz before recovering to the 2-3GHz+ range I expect out of the power level. Shorter stutter events don’t show as low a task manager clock, but I suspect that may have more to do with the windows task manager update speed.
Behavior from unplugging is a rather short stutter, but the plug in behavior lasts 1-5 seconds. In a particularly severe case I observed, the computer was in low power mode due to low battery, and when I plugged it in, it slowed down for enough time for the AMD driver to crash and generate a bug check/report window.
I have not tested whether this behavior persists without the GPU module attached, but it at minimum will persist between reboots.
This behavior exists on both the factory Framework charger and a UGreen 300w 5-port charger I had on hand (PD @ 140w max). If I use one of the lower watt outputs on the UGreen charger or the primary power from my FW13’s eGPU (intentionally underpowering the laptop to 40-60w), the stutter lasts shorter than the high-power stutter.
Moving my USB adapters around, I can confirm the behavior on 4/6 USB ports - the upper ones closest to the LCD panel (excluding the GPU USB-C port on the back). I did not test the remaining three USB ports.
I have a decent familiarity with digging into system issue (IT is my day job), so if there’s some specific diagnostic I can run, happy to help.
Specs:
FW16 DIY Edition
Ryzen 7 7840HS
32GB (1x32GB)
WD Black SN850X 1TB
FW 1TB expansion card
No SSD populated in the secondary bay
Radeon RX 7700S installed
