[SOLVED]? FW 16 won't charge
Hey all! My first post here, trying to get help with my recently bought Framework 16.
Charging was fine right out of the box, then started getting a little wonky - sometimes after replugging the charger, the laptop wouldn’t charge unless i flipped the usb c connector on the power brick the other side up (yes its weird, usb c is supposed to be double-sided but ive done this to solve problems with other dongles and whatnot - and it clearly helped here).
All was fine until yesterday - it stopped charging completely!
When plugging any other charger the laptop charges for a second or two, and then stops. The FW charger does not yield anything at all. I’ve tried rebooting a bunch of times, resetting BIOS to defaults, physically taking the battery out and plugging it back in - nothing helps
I have a Framework 16 on Windows 11, without the GPU expansion, and with 3 usb c’s, a usb a, a HDMI (that’s barely working out of the box but im already on it with the support team) and a 1tb storage card
Would appreciate any help on this a ton !!
Edit: Forgot to mention - the FW charger itself seems to be functional. It charges my phone and power bank perfectly fine
Unplug the power and long press the power button for 30s. Then retry to plug the power cable.
Retry those steps until it works (it should the first try dont worry).
Thanks for the reply !! I have tried this method before (though maybe I didn’t hold the power button for long enough)
Tried this again just now and it did nothing - though the laptop is completely drained and wont power on at all so me holding the power button down just might not be going through
UPDATE: it started charging again!! at 80W according to HWiNFO (not sure what it used to be prior, never bothered to check)
what i did was:
  • unplug EVERYTHING, even the cables attached to the power brick
  • wait a couple minutes?
  • plug it back in ??
I am really unsure about all this as even now when it did start charging, unplugging and plugging the cable back in does not immediately start charging, i still have to detach the power brick from its PS cable and reattach it, then it seems to charge properly. So in the end the issue might still be there… I’ll try to reinstall the latest BIOS update and the USB and battery drivers, see if there are any issues there
Perhaps try with a different cable? It might be a bad connection of the wire to the plug or internal to the plug (?)
ANOTHER UPDATE: I think i figured it out! I remember seeing in one of the community posts regarding a similar charging issue that the FW16 really doesnt like being charged from more than one source at once. Not that I’ve ever done that, but the usb c laptop dock station could have been contributing to this.
The laptop charges fine as long as the charger is connected, or unplugged and plugged back in within a short period of time (im talking 10-15 minutes short period of time), but consistently stops charging every time its unplugged for a long period of time with the usb c dock station connected.
What helps to fix this is quite bizzare but it works: I unplug everything from the laptop (which in my case is just the dock station), unplug the charger, and then reconnect it specifically with the 90 degree end of the FW charging cable to the laptop’s port 1 (the left top most one if youre looking at the opened machine from the front, I have a usb c expansion card in that slot)
Its kind of a weird issue to run into, but it might just be a usb c thing for all I know
I followed these instructions and it worked for me. I use my Framework 16 with both the 180W charger and an Anker 778 dock and I noticed it was no longer charging. I tried unplugging everything, holding the power button, and using the 180W charger with the straight end into the laptop. No dice. Then I used the right-angle end into the laptop and it’s now charging. Weird. Thanks for writing this up!
I suspect port 1 (back left) is broken on my main board. It does not charge my Framework 16 at all. All other ports charge just fine.
I also have another Framework 16 for personal use and all of its ports charge just fine as well. Going to submit a support ticket with Framework.
Look the documentation to reset the motherboard… It should work again after that.
Thanks! I did two processes. The first was holding the power button until everything shut down and then plugged in the charger. The second was opening the mid plate and pressing the tamper switch 10 times to reset the board. I observed that the BIOS was successfully reset which tells me the process worked.
However, none of those processes resulted in my port 1 charging. I tried different USB-C expansion modules and tried plugging the charger directly without an expansion module. No dice. All my USB-C expansion modules charge in ports 2, 4, and 5 so it’s not an issue there. Also port 1 itself is working with devices such as USB drives, SD cards, etc. It’s just charging that’s not working.
So I guess your next step is Framework’s support then … good luck !
Thank you! They asked me to record a video showing that the port works with devices but doesn’t charge. After that video they confirmed that the board needs to be replaced. Here’s the video for reference.
What documentation? I’ve never seen official Framework 16 documentation for how to do this, just random forum threads. Framework Laptop 16 - Framework Guides does not have anything that I’ve seen.
Under Framework 13 I found Fully Resetting the Mainboard State - Framework Guides , but that talks about an RTC battery which afaik don’t exist on the FW16. At least I don’t see any on mine.
All I can say is that I essentially always have 2 chargers plugged in. A 45W charger that’s connected to my dock for if I’m using steam deck docked, and the 180W FW charger that I plug in directly. It always correctly prefers the 180W charger.
Edit: forgot to mention that I had a similar issue that might help you:
[Resolved] Only Port 5 Charges | Ports 1,2,4 Do not charge - Framework Laptop 16 - Framework Community
I was able to get charging working again by using the BIOS to disconnect battery.
