FW16 Display Locked at 64Hz
My FW16 has the display currently locked to 64hz according to the Windows display properties and confirmed by ufo test. I tried reinstalling drivers and updating the bios but it isn’t fixed.
Also the brightness doesn’t change with the keyboard keys.
Windows 11 Home
No dGPU
Any Advice?
Press the “fn” button plus “ESC” and try the Brightness again
The “fn” button plus “ESC” Swaps the funktion with F1 - F12
To be clear the brightness is adjusted in windows, but that doesn’t change anything on the display.
One difference I notice is that it says it is using the Microsoft basic display driver on yours and the 780M on mine. What does it list on the Adapter tab next to the monitor? And have you tried installing something like AMD Adrenaline and using that to find/install drivers?
Plug the Display Cabel out and in again if you feel comfortabel doing it.
