Bro, wtf, just find the 7700s GPU runs slower than 7600s in notebookchecker, any thoughts?
It is possible that the ASUS is supplying 100+W to the 7600S and the cooler on the ASUS is able to more effectively dissipate heat.
This has occurred before with other GPU series. For example, some laptops with 4060s such as the Zephyrus series are able to easily outcompete RTX 4070s in other laptops such as the Acer Swift X because they have way higher power budgets and better cooling systems.
Looking up the specs on that Asus TUF with the 7600S it is utilizing a 240W charger and a likely much higher power budget for the GPU/CPU. Hopefully someone gets a 240W USB-C charger on the market in the next year or two but for now we are limited to 180W at the most, and that is only from Framework. The highest outside of Framework is 140W via USB-C.
Digikey sells a 240W charger that should be shipping at the end of the month.
