Same, Steve1. Kubuntu 22. Tried everything. No luck. Here’s what I did that worked:
Plug into a cable connection and get the internet
sudo apt install linux-modules-iwlwifi-generic
sudo reboot
Voila. SecureBoot too. Seems to work fine so far (an hour in).
Still having the problem that all FW >v63 is breaking Wifi, deleting all newer versions works - so far. But that is certainly not the future proof way to deal with it. Something is amiss and I have not found the right bug in the right issue tracker yet…
Just dropping this here:
On Ubuntu or Fedora you do not and should not need to do anything in the terminal to install Intel wireless. If you have, then I’d start over with a clean install of Ubuntu/Fedora.
Both Ubuntu 22.04/22.10 and Fedora 37 have the provided wireless card working out the box.
This is not entirely my experience. I’m running 22.04 (with kernel 5.15.0-25-generic) which indeed worked initially, but it seems to sometimes fail to initialize with the errors shown above (e.g. kernel: iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110). Because it is intermittent, maybe this problem did not show up in your testing. Or maybe there is something else different in the setup (maybe it depends on timing differences due to external hardware, or differences in kernel versions or so).
In any case, deleting 66.f1c864e0.0 ty-a0-gf-a0-66.ucode makes the problem disappear for me (by forcing the driver to fall back to the ty-a0-gf-a0-63.ucode version). I do have to delete the file again whenever a system update has reinstalled it (which happened just now, so I confirm this problem still exists for me).
Matthijs_Kooijman:
On Ubuntu 22.04 right now, not seeing this issue locally. I think you’re right about it being intermittent as I have not been able to duplicate this on a clean installation. Ubuntu has recommended (to us) that users are running them OEM kernel. Have you tried this? This is the kernel I use.
Edit: Fresh ISO of 20.04 .5 has kernel 5.15.0-46 -generic as the default.
I’m pretty sure I found that ucode fix on an Ubuntu forum somewhere ;- )
I have a Comet Lake wireless.
I am using Arch Linux
Bluetooth will not work in Linux but works in Windows
Here is some info on my system:
[ 4.583038] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 4.589847] iwlwifi 0000:00:14.3: Detected crf-id 0x3617, cnv-id 0x20000302 wfpm id 0x80000000
[ 4.589867] iwlwifi 0000:00:14.3: PCI dev 02f0/0074, rev=0x351, rfid=0x10a100
[ 4.597842] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 4.597854] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 4.598130] iwlwifi 0000:00:14.3: loaded firmware version 77.bd067429.0 QuZ-a0-hr-b0-77.ucode op_mode iwlmvm
[ 4.697490] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[ 4.820169] iwlwifi 0000:00:14.3: Detected RF HR B3, rfid=0x10a100
[ 4.886640] iwlwifi 0000:00:14.3: base HW address: 0c:dd:24:ab:82:13
[ 5.281200] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
System:
Kernel: 6.6.0-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet
udev.log_priority=3 acpi_osi=! "acpi_osi=Windows 2017"
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: plank wm: kwin_x11
vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.29 date: 11/02/2022
Battery:
ID-1: BAT0 charge: 61.7 Wh (90.1%) condition: 68.5/68.5 Wh (100.0%)
volts: 12.6 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: not charging cycles: 219
Device-1: hid-0018:04F3:2992.0003-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Memory:
System RAM: total: 16 GiB note: est. available: 15.26 GiB
used: 6.01 GiB (39.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF8
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1800 high: 1802 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1800 2: 1800 3: 1800
4: 1800 5: 1800 6: 1802 7: 1800 8: 1800 bogomips: 36812
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities:
Type: gather_data_sampling mitigation: Microcode
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: retbleed mitigation: Enhanced IBRS
Type: spec_rstack_overflow status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Type: srbds mitigation: Microcode
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 3b:00.0 chip-ID: 10de:1d13
class-ID: 0302
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 220 s-size: 443x249mm (17.44x9.80")
s-diag: 508mm (20.01")
Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9b41 memory: 14.9 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce MX250 driver: nvidia v: 545.29.02 device-ID: 10de:1d13
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
(CML GT2) driver: mesa intel v: 23.1.9-manjaro1.1 device-ID: 8086:9b41
surfaces: xcb,xlib
Audio:
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
API: ALSA v: k6.6.0-3-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsactl,alsamixer,amixer
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Network:
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlan0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
WAN IP: <filter>
Bluetooth:
Message: No bluetooth data found.
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 931.51 GiB used: 301.45 GiB (32.4%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
Message: No optical or floppy data found.
Partition:
ID-1: / raw-size: 163 GiB size: 160.13 GiB (98.24%) used: 71.03 GiB (44.4%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: Manjaro
uuid: 45ca132d-4a37-4dc3-afa0-be2e80d6a4a2
ID-2: /boot/efi raw-size: 499 MiB size: 498 MiB (99.80%)
used: 415.6 MiB (83.5%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 562D-988E
ID-3: /home raw-size: 410.57 GiB size: 403.06 GiB (98.17%)
used: 230.02 GiB (57.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: Data for Manjaro uuid: 1f7a0eb8-f3e9-46ef-a88a-e3ae0ed0233d
ID-4: /home/<filter>/mnt/server/music raw-size: N/A size: 2.72 TiB
used: 1.62 TiB (59.6%) fs: cifs dev: /dev/Music
Swap:
Alert: No swap data was found.
Unmounted:
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 28C6655CC6652AF0
ID-2: /dev/nvme0n1p11 maj-min: 259:10 size: 16 GiB fs: swap label: N/A
uuid: 1b9cd8e2-756a-4a24-9641-d3cdd3bed29a
ID-3: /dev/nvme0n1p12 maj-min: 259:11 size: 3 MiB fs: ufs label: N/A
uuid: 6354a81a1b0b8929
ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/nvme0n1p4 maj-min: 259:4 size: 218.98 GiB fs: ntfs label: N/A
uuid: EAEA681CEA67E375
ID-6: /dev/nvme0n1p5 maj-min: 259:5 size: 961 MiB fs: ntfs label: N/A
uuid: 863E127D3E126709
ID-7: /dev/nvme0n1p6 maj-min: 259:6 size: 90 GiB fs: ext4 label: N/A
uuid: d702f568-b918-4354-874a-f1d82eaf1f37
ID-8: /dev/nvme0n1p9 maj-min: 259:9 size: 31 GiB fs: ext4 label: N/A
uuid: 91f4ccdf-2376-48ab-a390-91ea0bc4b02a
USB:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002
class-ID: 0900
Device-1: 1-1:2 info: Elan Micro Wireless Keyboard type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 04f3:01a4 class-ID: 0301
Device-2: 1-9:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:00bb class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003
class-ID: 0900
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
class-ID: 0900
Hub-4: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
class-ID: 0900
Sensors:
System Temperatures: cpu: 63.0 C pch: 63.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Processes: 286 Uptime: 11h 51m wakeups: 2 Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 1905 libs: 465
tools: pacaur,pamac,pikaur,yay pm: rpm pkgs: 0 Shell: Bash v: 5.2.15
running-in: alacritty inxi: 3.3.31
Folks, I want to be clear.
On supported Ubuntu 22.04.3 using the correct OEM C kernel, nothing is needing to be compiled, etc, with Intel wireless.
The moment you start copying stuff from random forums, my ability to replicate goes out the window.
If however, this appears to be untrue in your situation, please provide me with the output of:
sudo lshw -C network | grep -A 12 -i 'Wireless'
This will assume you’re on a supported distro such as Ubuntu 22.04.3 or Fedora 38/39.
Ivor
June 4, 2024, 2:24am
51
What’s up everyone. Though I don’t own a Framework laptop, I’m running Mint 21.3 and just did something that worked for me.
I went to the Intel Linux Driver Downloads page from Foxtrek_64’s orignal post
I ran the following command…
lspci | grep -i net
to find out what wireless adapter i had in my computer. it returned…
04:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
I went onto the driver downloads page, and using ctrl+f typed in “7265” and i downloaded the corresponding drivers (for me, those were the “Intel® Dual Band Wireless-AC 7265, Intel® Dual Band Wireless-N 7265, Intel® Wireless-N 7265” drivers, kernel 4.2+) to my downloads folder.
I extracted the tar file to downloads. The folder was named “iwlwifi-7265-ucode-25.30.14.0” Inside were the following:
a. iwlwifi-7265-14.ucode
b. iwlwifi-7265D-14.ucode
c. LICENSE.iwlwifi-7265-ucode
d. README.iwlwifi-7265-ucode
Here’s the important piece. In Foxtrek_64’s original post, they said that the only thing that was to be replaced was the version number of the driver. I tried that originally, but nothing worked, basically because the directory didn’t exist. Here’s one such error that the terminal returned on my numerous attempts.
cp: cannot stat 'iwlwifi-ty-a0-gf-a0-14.gcode': No such file or directory
What worked for me was setting the cd to the extracted folder, then using sudo cp to copy the .ucode file to /lib/firmware. It looked like this:
cd /home/ivor/Downloads/iwlwifi-7265-ucode-25.30.14.0
sudo cp iwlwifi-7265-14.ucode /lib/firmware
reboot. it’s been working for as long as it took me to write this post so i hope it helps someone else. the main takeaway is to sudo cp the entire filename, not just change the version number.
edit: accidentally pressed ctrl+enter
2: clarity
