Hard freeze when opening Brave
Hello,
I’m a new framework user, just bought it 2 weeks ago (Ryzen™ 9 7940HS).
I’m running a Linux Ubuntu 24.4.2 LTS
I’ve installed Brave, added my pinned pages (8, like gmail and some others).
Next reboot, when I launch brave, my screen just freeze, nothing I can do about it except pressing the power button for X seconds to shut down the laptop.
It’s not like it makes any sound, like a fan sound because it’s hot or something.
I even waited for 30 minutes, nothing changed.
Any idea of what is causing that ?
I’m worried that it could happen anytime when it will be my only computer (I’m still relying on my previous one because of that).
Thank you for your time reading this
Sounds like it could be a graphics driver crash. Try getting some kernel logs for the boot where Brace was opened. Since you have hard-rebooted, you want the “previous” boot’s kernel logs so something like this should print them: journalctl -k -b -1
Thanks for the answer.
Here it is :
mai 04 16:48:05 xxx-laptop kernel: loop16: detected capacity change from 0 to 104232
mai 04 16:48:05 xxx-laptop kernel: audit: type=1400 audit(1746370085.961:194): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/snap/snapd/24505/usr/lib/snapd/snap-confine" pid=4676 comm="apparmor_parser"
mai 04 16:48:05 xxx-laptop kernel: audit: type=1400 audit(1746370085.962:195): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/snap/snapd/24505/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=4676 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.202:196): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.keepassxc" pid=4680 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.452:197): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.spotify" pid=4684 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.475:198): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.slack" pid=4681 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.505:199): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.firefox" pid=4678 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.512:200): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.snapd-desktop-integration" pid=4683 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.521:201): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.snap-store" pid=4682 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.537:202): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.firmware-updater" pid=4679 comm="apparmor_parser"
mai 04 16:48:06 xxx-laptop kernel: audit: type=1400 audit(1746370086.542:203): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.docker" pid=4686 comm="apparmor_parser"
mai 04 16:48:10 xxx-laptop kernel: loop17: detected capacity change from 0 to 8
mai 04 16:48:11 xxx-laptop kernel: kauditd_printk_skb: 32 callbacks suppressed
mai 04 16:48:11 xxx-laptop kernel: audit: type=1400 audit(1746370091.590:236): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/snap/snapd/24505/usr/lib/snapd/snap-confine" pid=5385 comm="apparmor_parser"
mai 04 16:48:11 xxx-laptop kernel: audit: type=1400 audit(1746370091.604:237): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/snap/snapd/24505/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=5385 comm="apparmor_parser"
mai 04 16:48:11 xxx-laptop kernel: audit: type=1400 audit(1746370091.839:238): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.spotify.hook.configure" pid=5388 comm="apparmor_parser"
mai 04 16:48:11 xxx-laptop kernel: audit: type=1400 audit(1746370091.858:239): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.firmware-updater.hook.configure" pid=5394 comm="apparmor_parser"
mai 04 16:48:11 xxx-laptop kernel: audit: type=1400 audit(1746370091.863:240): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.snap-store.hook.configure" pid=5396 comm="apparmor_parser"
mai 04 16:48:11 xxx-laptop kernel: audit: type=1400 audit(1746370091.891:241): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.snapd-desktop-integration.hook.configure" pid=5400 comm="apparmor_parser"
mai 04 16:48:12 xxx-laptop kernel: audit: type=1400 audit(1746370092.012:242): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.firmware-updater.firmware-updater" pid=5392 comm="apparmor_parser"
mai 04 16:48:12 xxx-laptop kernel: audit: type=1400 audit(1746370092.123:243): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.spotify.spotify" pid=5389 comm="apparmor_parser"
mai 04 16:48:12 xxx-laptop kernel: audit: type=1400 audit(1746370092.162:244): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.firefox.hook.configure" pid=5405 comm="apparmor_parser"
mai 04 16:48:12 xxx-laptop kernel: audit: type=1400 audit(1746370092.166:245): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.snap-store.snap-store" pid=5398 comm="apparmor_parser"
mai 04 16:48:14 xxx-laptop kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
mai 04 16:48:17 xxx-laptop kernel: loop17: detected capacity change from 0 to 151328
mai 04 16:48:33 xxx-laptop kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
mai 04 16:48:57 xxx-laptop kernel: warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Is there more? This looks like only part of a boot, on the earlier side. There should be quite a bit before and especially after this.
What you can read is what happened just before the freeze : the computer was on since 8 minutes when this happened.
I was copying files from USB key to M2 storage, then I opened brave, it freezed instantly.
No other logs was found after.
I am running Brave daily on Ubuntu 24, never had an issue like yours (or any other issue).
This won’t fix your issue, I just wanted to let you know on a plain vanilly Ubuntu 24, Ryzen 7, NO dedicated graphics, there is no issue.
I believe your issue is likely related to graphics.
