Hello, I’m just finishing spending the past month setting up my new top-tier batch 7 frame.work laptop, and I’m recently having some audio problems. Any idea what’s going on here and how I can further characterize it?
On support’s advice, I tried disconnecting my Dell U2421HE hub monitor with secondary DisplayPort MST monitor U2419H connected.
Also, I made a change whereby Firefox can now run across multiple CPU cores as I noticed that the CPU was pegged at 25% (on a quad core system), now it consumes more than 25% when busy.
Here are the numbers I got : better (I noticed audio dropouts when I connected my Razer Kraken 7.1 Chroma headphones to the hub monitor, but not when I pulled the USB-C to the hub monitor and plugged the headphones directly to the frame.work PC)
Just attended a one-hour Zoom meeting, getting lots of audio pauses (literally 20 second pauses when even doesn’t work and Ctrl Alt Del doesn’t automatically respond. My Task Manager says 100% CPU is being used, which is highly unusual. The machine is now quiescent but is still showing at 100%y, with system interrupts showing 99.6% CPU utilization.
Do a clean rebuild. It’s what I’d do.
I already had my geek Squad tech agent do a clean rebuild two months ago, same issues persist.
Support says they cannot help and that it is due to my peripherals, but I have no peripherals plugged in other than my headphones.
I tried a few other things, I unplugged my headphones and plugged in my USB-C connection to my two Dell monitors (DisplayPort MST enabled for the second Dell). I got occasional audio dropouts, but nowhere near as bad as when the Razer headphones were plugged in.
I also tried disconnecting my USB-C connection and Razer headphones, just doing Spotify to onboard audio, and although the CPU utilization remained high, I didn’t notice any audio dropouts.
I’ll try calling Razer support, but they will likely push back to the laptop manufacturer ![]()
In this next exciting installment, I have my frame.work connected via wifi only, no external connection other than my Razer 7.1 chrome headphones plugged into a USB-A port. I’m getting audio pops/drops all over the place.
SpeedTest Ookla results : 69 Mbps down, 76 Mbps up, completely sufficient for one Spotify channel.
Resurrecting this thread as I have the exact same issue. DIY 11th gen, audio from spotify stutters terribly when moving the mouse. It’s utterly unusable.
