HDMI not detected after resuming from suspend
Ubuntu 24.04.2 LTS
Which release version?
Which kernel are you using?
6.14.0-28-generic
03.04
AMD Ryzen AI 7 350 w/ Radeon 860M
Behavior: HDMI port is in the front right slot. Second monitor is working. I close the laptop and disconnect the HDMI cable. I wait 10 minutes (once when still plugged into power, once on batter). I open the laptop and plug the HDMI cable back in. External monitor is not detected. If I reboot the laptop, the external monitor will be detected again.
Expected behavior: The external monitor will be detected when I plug in an HDMI cable, even after resuming from suspend.
Any suggestions?
Thank you!
@Michael_Weinberg Any docks or switches being used? Asking as you mentioned a second monitor… not sure if you meant second external monitor or not.
You may want to shoot our support team a message here so our Linux team can take a look, if needed.
No docks or switches - just an HDMI cable into the monitor. I’ll hit up the Linux team. Thanks!
Did you have any improvement since your post? I have the same model with 3.05 BIOS and have this issue. I can fix it by plugging the expansion card on the other side of the laptop (from right to left or left to right). It’s an absurd situation. The support asked me to gather some logs.
By the way, I have issues with expansion cards that disconnect sometimes. I use Debian testing with 6.18.9 kernel.
I get this issue on Arch Linux with kernel 6.18.9 on a Ryzen AI 7 350
