You forget how litigious the US is, which was kinda my whole point with the McDonald’s remark.
I’m not considering anything of the sort, myself, and am a huge supporter of Framework…hence my concern.
You either don’t own one of the 1TB expansion cards or are intentionally trying to gaslight my point with “warm plastic.” The expansion card casing side facing the user is, in fact, metal, not plastic, which does directly transfer all of that heat to anything touching it. I measured the metal housing at over 55C with a thermal probe directly on the exterior, not the NAND inside the case. The expansion card is using the Aluminum portion of its shell as a heatsink and that casing can easily exceed the medically established thresholds for direct contact burn risk when under sufficient load.
You dismiss the concerns of others in such an out-of-hand manner. Do you even have the 1TB expansion card? Have you felt, for yourself, how hot it gets under load? Ever had that expansion card resting on your thigh for an extended period of time while clacking away on your keyboard? Even at idle, it gets unpleasant fast. Under load, I can no longer keep my laptop directly on my lap, even through pants. Thankfully, I typically prefer to use a lap-pad surface if I’m using my laptop for extended periods for greater comfort, but the excessive heat is still a concern for anyone with more sensitive skin (or who is wearing shorts, even).
I think, at the very least, in order to cover their collective asses against such litigious risks, they should do a better job of warning of the temperatures on the product page. A properly highlighted warning - just like the Prop 65 warning they already show on the product page - can equate to millions in protection from lawsuits. Why do you think the word “HOT!” now appears no less than 10 times on a McDonald’s cup of coffee!? (coming full circle to my original point) The very essence of Consumer Protection is catering to the least knowledgeable [edit: and vulnerable] among us, no matter how obvious it may seem to you.
And, to be clear, even product recalls over excessive flash storage temps are not unheard of. Lexar had to recall early JumpDrives because they used metal for the housing and the larger size models were getting way too hot while under load. They were among the first to market with 2GB flash drives in such a small form factor and ended up having to recall them:
My whole point is, such high densities in such a small space operating at such high speeds is literally and metaphorically flying close to the sun; a fact that every storage company has acknowledged, with many NVMe drives now effectively requiring a heatsink to prevent performance throttling. Framework needs to tread a little more carefully and communicate better, considering they are such a young company. One bad recall and/or lawsuit could set them back for a decade…or worse. I would never want to see something like that happen to such a great company!
